MontyRisk
(Monty Risk)
1
Since this isn’t working, I must be doing something wrong. I am looking to use this create some sensors when certain equipment is running.
This returns: fan,heatPump
{{ states.climate.home.attributes.equipment_running}}
This returns: off
It should be returning on, why is that?
{% if states.climate.home.attributes.equipment_running in ['fan'] %}
on
{% else %}
off
{% endif %}
tom_l
2
Because “fan,heatPump” is not in [‘fan’]
‘fan’ is in [‘fan’ ,’ heatPump’]
Two different logical tests.
Try this:
{% if 'fan' in state_attr('climate.home', 'equipment_running') %}
on
{% else %}
off
{% endif %}
How are you using this template?
I suspect there is a better way, please show the full sensor config.
MontyRisk
(Monty Risk)
3
In the developer > template editor it worked.
When I added it to an automation, I ran into issues referring to the first if line:
while scanning for the next token found character ‘%’ that cannot start any token
value_template:
on
{% else %}
off
{% endif %}
tom_l
4
value_template: >
Please post the rest of your sensor.
MontyRisk
(Monty Risk)
5
sensors:
hvac_humidifier:
friendly_name: 'HVAC Humidifier'
value_template: >
{% if 'humidifier' in state_attr('climate.home', 'equipment_running') %}
on
{% else %}
off
{% endif %}
tom_l
6
Ah, that’s what I though. If it only has two states use a binary sensor:
binary_sensor:
sensors:
hvac_humidifier:
value_template: "{{ 'humidifier' in state_attr('climate.home', 'equipment_running') }}
If the template evaluates to true the state will be on
and likewise off
for false. This will be displayed capitalised in the Lovelace frontend.
MontyRisk
(Monty Risk)
7
Thank you, worked like a charm!
