I’m working on converting an automation of mine to a Blueprint, the automation itself sends a notification that a lock has been unlocked for x
using the template {{states.lock.front_door.last_changed | relative_time}}
In my Blueprint I have
variables:
lock_entity: !input lock
which works great when I use it like {{state_attr(lock_entity,'friendly_name')}}
but not when I try {{states.lock_entity.last_changed | relative_time}}
. It instead returns None
. Any clues on how to effectively use the variable (or the plain !input lock
) in the template to get the last_changed
value?
If you have lock in HA, you can recreate this simply in template tab of Developer Tools with
{% set lock_entity = 'lock.back_door' %}
Works: {{state_attr(lock_entity,'friendly_name')}}
Returns None: {{states.lock_entity.last_changed | relative_time}}
