Using CATT
hi @Luitertje,
Unfortunately that log part was indeed containing a type because of I tried some commands. So both don’t work, not directly in the SSL terminal, nor from a shell command. Both attempts:
Double ""
ssh -o StrictHostKeyChecking=no -i /config/ssh/rsa_key [email protected] catt -d "Google nest hub" cast_site https://XXXXXXXXX/lovelace-hub/0
Single ''
ssh -o StrictHostKeyChecking=no -i /config/ssh/rsa_key [email protected] catt -d 'Google nest hub' cast_site https://XXXXXXXXX/lovelace-hub/0
Solved,
The issue was that the name of the cast device contained a whitespace. I changed Google nest hub to Hub and now the issue is fixed.
So in my case the issue return code: 2 was fixed by clearing the whitespaces in the casting device name.
same issue here, no idea how to get it running
Up to date Home Assistant install.
I’ve installed CATT using “pip3 install catt” via ssh.
I can run the “catt -d …” command successfully to my Nest Hub
If I reboot home assistant CATT is still installed.
However if I make a change to SSH & Web Terminal and restart SSH, CATT needs reinstalling.
I have a script in /config/bash/ called update_catt.sh, which does install CATT using the command “bash /config/bash/update_catt.sh”.
configuration.yaml has the following entry:
shell_command:
# CATT
  update_catt: bash /config/bash/update_catt.sh
This automation doesn’t work
What am I missing ?
alias: "CATT: Init"
description: Installs the latest version of CATT on Home Assistant start
  - platform: homeassistant
    event: start
condition: []
  - service: shell_command.update_catt
    data: {}
  - service: notify.notify
      message: CATT install triggered.
mode: single
Update: I know the automation is executing because I receive the notification.
Just that CATT isn’t installing.
Did you find any solution to the https issue using private IPs?
Nope. I just have up setting up home assistant direct access via Google nest hub
hello
really nice with ha-catt-fix this saves me having to see the recast screen all the time.
But one thing this appears to only work when I have internet access and most times that is ok but lately my internet connection are not that good so I’m trying to make this work local
I have added cast_receiver_framework.js and google-nest-hub.png to my www folder
I have tried using a local adress const cast_api = “//http://192.168.1.226:8123/local/cast_receiver_framework.js”;
and adding the file directly script.src = ‘./cast_receiver_framework.js’;
and its not working
might be be because I have really no clue what I’m doing… but I have been searching and reading and I’m not any closer at all to figure this out
so any ideas or anything?
ha-catt-fix.js(part of it with my tests)
//const cast_api = "//http://192.168.1.226:8123/local/cast_receiver_framework.js";
const cast_api = "//www.gstatic.com/cast/sdk/libs/caf_receiver/v3/cast_receiver_framework.js";
// Taken from: https://stackoverflow.com/a/14786759
function loadScript(url, callback) {
  var head = document.getElementsByTagName("head")[0];
  var script = document.createElement("script");
  script.type = "text/javascript";
  //script.src = url;
  script.src = './cast_receiver_framework.js';
  script.onreadystatechange = callback;
  script.onload = callback;
  head.appendChild(script);
// Taken from: https://github.com/home-assistant/frontend/blob/69264b3448e9862025e78090a52af20f796aa32b/cast/src/receiver/entrypoint.ts
function playDummyMedia() {
  const loadRequestData = new cast.framework.messages.LoadRequestData();
  loadRequestData.autoplay = true;
  loadRequestData.media = new cast.framework.messages.MediaInformation();
  //loadRequestData.media.contentId = "https://cast.home-assistant.io/images/google-nest-hub.png";
  //loadRequestData.media.contentId = "http://192.168.1.226:8123/local/google-nest-hub.png";
  loadRequestData.media.contentId = '/.google-nest-hub.png';
  loadRequestData.media.contentType = "image/jpeg";
  loadRequestData.media.streamType = cast.framework.messages.StreamType.NONE;
  const metadata = new cast.framework.messages.GenericMediaMetadata();
  metadata.title = "Dummy " + (new Date().toTimeString());
  loadRequestData.media.metadata = metadata;
  loadRequestData.requestId = 0;
  window.playerManager.load(loadRequestData);
  window.setTimeout(playDummyMedia, 60 * 9 * 1000);
I couldn’t get it working for me using catt directly on Home Assistant so I’ve created my own ‘ha-cast’ service that runs on a Raspberry Pi continuously and restarts on boot. The service checks the status of all configured Chromecast devices from the config.yaml file and will only cast if there is no media/dashboard already playing. It iterates over every 10 seconds and sleeps throughout the night.
If you want to try it out yourself, here’s the project: GitHub - b0mbays/ha-cast: Python system service to continuously cast Home Assistant to a Google Chromecast device
Hi - should this work with Google TV’s ambient mode? I’ve installed ha-catt-fix and am using Home Assistant’s cast.show_lovelace_view service to cast a dashboard to a Chromecast with Google TV device (connected to a TV).
The problem is that after 10 minutes the CCGTV goes into ambient mode (where it displays whatever is configured e.g. random Google Photos pictures). I was hoping this fix would stop it going into ambient mode, but not sure if it is applicable to CCGTV devices.
