lucianv
(Lucian)
November 3, 2023, 4:24pm
1
Hi all,
Maybe is a stupid question but looking on a lot docs found over internet I am still not clear about wiring CD74HC4067 module to esp32. Target is to add a 16 relay to HA using this.
So to which esp32 pins should I connect SIG / S3 / S2 / S1 / S0 / En ?
Thank you in advance
nickrout
(Nick Rout)
November 3, 2023, 7:36pm
2
lucianv
(Lucian)
November 6, 2023, 8:59am
3
Thank you
Can you point me to an example to use for control I/O ? I want use it to control a 16 channel relays board
Thanks a lot
nickrout
(Nick Rout)
November 6, 2023, 9:19am
4
Actually, the chip is bidirectional and could also be used as output, but this is not supported by the component yet.
I pointed to the page already.
lucianv
(Lucian)
November 6, 2023, 9:30am
5
i see the page but there are only sensors . …
i don t see any on/off use of the outputs
I will try to figgure it out then, thanks
nickrout
(Nick Rout)
November 6, 2023, 9:38am
6
lucianv
(Lucian)
November 6, 2023, 9:41am
7
oh…then this is why i could not find any of example about this…
thank you
