Using Climate_IP to control Samsung mini splits
Hi all. I’ve just gotten into HA and have been using it for about a month. Love that I can combine all my various smart things into one interface!
I’ve been wondering, though, about controlling my Samsung mini split. It’s from about 2015. Model number is AR24HSFSJWKNCV. I’ve read a LOT of old forum posts and discovered that (I think?) mine is controlled by port 2878, not 8888. (Although, how can I be sure?). I’ve determined that I think I need to use Climate_IP. I need to get the token from the device. But, all the various Python script methods throw all kinds of errors. My programmer friend figured out that it’s probably because those were written with such old versions of Python and needs to be updated now.
I have Climate_IP installed through HACS and I actually got it to show up in my dashboard, but it always shows “off” and doesn’t do anything when I change any of the controls / settings.
The original app that controlled this device is Samsung Smart Air Conditioner. It stopped working in new versions of Android years ago. I found an old phone I have from 2017/18 and the app is still installed on there and it is, indeed, functional. This AC, though, does not appear to function with Samsung Smart Things. If it did, I could use that integration.
I think the crux of this issue is not being able to retrieve the token from the device because I can’t get any of the Python stuff to work. Any ideas?
I figured it out!!! I used this, in case anyone else has the problem:
