I am not sure why this automation doesn’t pass the Check Config test. Any ideas?
##### Manual Setting/Unsetting of Downstairs Away Mode for Thermostats
- id: downstairs_away_mode
alias: Downstairs Away Mode
- platform: state
entity_id: input_boolean.downstairs_away_mode
## Turn on/off thermostat "Away Mode".
- service: climate.set_preset_mode
data_template:
entity_id:
- climate.basement_heater
- climate.shop_ac
- climate.shop_heater
- climate.finishing_room_heater
preset_mode: >
{% if trigger.to_state.state == 'on' %}
away
{% else %)
none
(% endif %)
I get the following error:
Invalid config for [automation]: invalid template (TemplateSyntaxError: expected token 'end of statement block', got '%') for dictionary value @ data['action'][0]['data_template']['preset_mode']. Got None. (See /config/configuration.yaml, line 185). Please check the docs at https://home-assistant.io/components/automation/
If I just set preset_mode': 'away'
then the config check passes.
