Hi Guys,
I am using fibaro HC2 for all my z-wave devices (mostly fibaro). Recently I moved to HA, but am not able to use the devices because they are discovered as entities in Automation. I am not able to set proper conditions or actions and other limitations.
Any suggestions on that?
This should go in #configuration. Anyway are you sure there are no devices? What platform are you using for z-wave?
You don’t need a device to create automations or conditions. That is a growing misconception. Every that needs to be done can be done with entities. Device (and device triggers) are relative new, before they existed we could automate too ! Just use a state or other trigger.
Thanks. I tried it in different ways for tigers and conditions os somehow the automation does not fire at all. I am not able to troubleshoot to trace where exactly the chain is breaking.
For example, I have 2 motion sensors (one is fibaro via HC2 and the other one is part of my EVO192 Paradox alarm system) in my hallway and I want to turn on the lights when either of them detects motion (for more precise detection), but only if the lights are turn_off:
alias: Antre auto ON on motion
description: ''
- platform: state
entity_id: binary_sensor.corridor_antre_motion_144
for: '00:00:00'
to: 'on'
condition:
- condition: or
conditions:
- type: is_motion
condition: device
device_id: 124b534922a44f1bae21dfcc778d1a92
entity_id: binary_sensor.zone_012
domain: binary_sensor
- condition: and
conditions:
- condition: state
entity_id: light.corridor_antre_main_light_111
state: turn_off
for: '00:00:00'
- service: light.turn_on
mode: single
If I add only one of the motion sensors and remove the condition for the lights it works but very very slow (it takes at least 5 seconds to fire).
I have a few other automation and scenes that I am not able to trace/troubleshoot because when I run them manually they all work fine, but does not fire automatically on the trigger (motion or Alexa voice routine)
Fibaro HC2
That automation does not fill the description. It turns the light on if binary_sensor.corridor_antre_motion_144 is turned on, but only if binary_sensor.zone_012 is also on.
If I want to control anything when one out of two motion sensors are on, I use a third, compound template motion sensor.
Example :
sensors:
eetkamer3_occupancy:
friendly_name: "Eetkamer3 occupancy"
value_template: >
{{ is_state('binary_sensor.eetkamer_occupancy','on') or is_state('binary_sensor.eetkamer2_occupancy','on') }}
device_class: motion
