I currently have all my Z-Wave and ZigBee devices integrated into HA through my old Hubitat hub. This is because my current HA box doesn’t have either Z-Wave or ZigBee, and it’s worked fine like this so far. All of my Z-wave light switches support assigning different functions when I double tap either the on or off buttons. I’d like to utilize this feature in HA, but I’m not sure how to do it. It doesn’t look like the support is built in (possibly since the devices are being routed through Hubitat). The only way I’ve thought of so far is to set up a virtual button in Hubitat that is triggered when I double tap a switch, and then share that virtual button to HA in order to use it to trigger something (automation, scene, etc…). If there’s a better and/or easier way to do this, I’d appreciate it if someone could point me in the right direction. Thanks!
UPDATE: I was actually wrong, and the support is built in with the Hubitat integration. I found it in the automation section when picking one of my compatible switches as a trigger. Not sure how I missed it until now.
