I’m hoping someone can help me out here because I’ve searched high and low over the internet the past few days and am starting to lose my mind.
I have a physical Philips Hue bridge and lights, the Logitech Harmony Companion and I want to assign the home control buttons on the remote to scenes, which I know can’t be done without intervention.
This is the remote I have, and these are the buttons I want to program with light scenes.
I’ve been playing around with Emulated Hue, assuming that’s the route to go. But now I’m not so sure.
The scenes I want to control were created within the iOS Home app (not sure if that matters and if I need to recreate them elsewhere) - one is ‘TV Mode’ which basically dims my three Philips bulbs in the living room; the second is ‘Normal Mode’ which turns them back up to 100% brightness.
What is the simplest way to do this, please?
Below is a section of my configuration.yaml for Emulated Hue:
host_ip: !secret ha_ip_address
listen_port: 8300
advertise_ip: !secret ha_ip_address
advertise_port: 8300
upnp_bind_multicast: true
off_maps_to_on_domains:
- script
- scene
expose_by_default: false
exposed_domains:
- light
- switch
- input_boolean
- group
entities:
light.hh_dimmer:
hidden: false
And then I have another YAML - light_group.yaml - as below:
lights:
hh_dimmer:
friendly_name: "HH"
turn_on:
turn_off:
set_level:
When I navigate to http://myIP:8300/api/pi/lights I see the following:
"1": {
"state": {
"on": false,
"reachable": true,
"mode": "homeautomation",
"bri": 1
"name": "HH",
"uniqueid": "00:eb:5b:f5:28:00:21:f3-2a",
"manufacturername": "Home Assistant",
"swversion": "123",
"type": "Dimmable light",
"modelid": "HASS123"
And when I navigate to http://myIP:8300/description.xml, I see the following:
<root xmlns="urn:schemas-upnp-org:device-1-0">
<specVersion>
<major>1</major>
<minor>0</minor>
</specVersion>
<URLBase>http://REDACTED:8300/</URLBase>
<device>
<deviceType>urn:schemas-upnp-org:device:Basic:1</deviceType>
<friendlyName>Home Assistant Bridge (REDACTED)</friendlyName>
<manufacturer>Royal Philips Electronics</manufacturer>
<manufacturerURL>http://www.philips.com</manufacturerURL>
<modelDescription>Philips hue Personal Wireless Lighting</modelDescription>
<modelName>Philips hue bridge 2015</modelName>
<modelNumber>BSB002</modelNumber>
<modelURL>http://www.meethue.com</modelURL>
<serialNumber>001788FFFE23BFC2</serialNumber>
<UDN>uuid:2f402f80-da50-11e1-9b23-001788255acc</UDN>
</device>
</root>
So it would appear everything is setup as it should be, although I’m not sure I need to do it this way, i.e. creation of two lights via the light
protocol, creation of a group
, and then the entities
within the Emulated Hue declaration - seems overkill, but I don’t know.
Within the Home app, I can see the following: https://imgur.com/VyYtfxA.
All looks good so far.
And I can even get as far as opening the Harmony iOS app and going to Devices > Add Device > Home Control and Philips Hue does appear in there. It will try to connect and then I get the following screen:
But then it goes back to the Add Device page having not added the device. I then have to re-sync the Harmony app before it will appear again, and then the same thing happens again and again.
So… that is as far as I can get! Any help and support would be massively, massively appreciated. If I can program those home control buttons I’ll be a happy guy!
