I’ve installed the file editor and am in the web UI. I clicked the folder icon to to open the file browser sidebar.This is where I get lost. The doc says " * Click the configuration.yaml file (in the /config/ folder) to load it into the main file editor window."
But there is no /config/ folder in the side bar. I appear to be in a folder called homeassistant/. There is a back button that when clicked on does nothing. I also can’t tell where the current folder is in the overall file hierarchy. Is this just out of date documentation or am I missing something?
Thank you for confirming that that is the right configuration.yaml file and that homeassistant/ is the same thing as /config/. I’ll leave some feedback on the page. Much appreciated!
I realize you’ve already marked this closed, but you really should edit configuration.yaml is something like Visual Studio Code, so you get colored keywords and formatting identification. It’ll make your life a LOT easier.
It’s available in HA as the add-on “Studio Code Server”, and then you can edit files right from within the HA UI. Super easy.
I’ll be making a video about how to install and use it here shortly on my channel. If I remember, I’ll come back here and post a link in case you had any troubles, or want to switch from whatever it is you’re currently doing.
I was trying to edit the configuration.yaml file also and trying to find it based on the documentation which still says it’s in the /config/ folder. So this is just a reminder that the documentation still needs to be updated to state that the configuration file is in /homeasssistant/
Depends how you look. If you use the samba add-on, it is still called /config . If you use the file editor, it is called /homeassistant . Confusing at least.
