Using Flex Grow with Row Wrap
Currently Trying to make some Lvgl Code that is Portable across different resolution Devices.
Using Percentages instead of fixed Height/Widths.
Have 2 working Examples, but finding filling the Screen width in one case is a Problem.
My two Examples look Like this:-
And This:-
The first one Is fine, but it’s using 2 objects, one for each row of buttons.
The second has all the buttons in one object,
but if I try & use flex_grow, I end up with 8 buttons on a single row.
Can I work around this, or do I just need to stay with the two objects?
The two different Code blocks are as follows.
Edit: I’ve Tried Fine Tuning the Width %, without much Luck,
Have Also Tried using:
min_width: 23%
max_width: 25%
On the Assumption that that might of restricted to Flex_grow that was applied to each button.
Top Image:-
#----- TV Page --------------------------------------------------------------------------------------------
lvgl:
  pages:
    - id: Right_Tv
      bg_color: BLACK
      scrollable: "OFF"
      widgets:
        - obj:
            align: TOP_MID
            styles: header_footer
            widgets:
              - label:
                  text: "\U000F0606  ESPHome Bbq TV  \U000F0606"
                  align: CENTER
                  text_align: CENTER
                  text_color: WHITE
                  text_font: roboto_24
#----- Container for 1st Row Channel Buttons
        - obj:
            pad_all: 0
            bg_color: GREEN
            bg_opa: 35%
            border_color: RED # Was CYAN for Testing.
            border_opa: 50%
            align: TOP_MID
            bg_grad_dir: NONE
            width: 100%
            height: 25%
            y: 50
            layout:
              type: FLEX
              flex_flow: ROW
              flex_align_cross: STRETCH # Was CENTER
            text_align: CENTER
            text_font: roboto_icons_36
            scrollbar_mode: "OFF"
            scrollable: false
            widgets:
              - button:
                  height: 100%
                  flex_grow: 1
                  widgets:
                    - label:
                        text: "ABC HD\n20"
                        styles: s_rlybtn
                  checked:
                    styles: s_rlybtn_ck
                  on_click: # on_press Triggers Immediately, on_click Triggers on Release if within defined time frame
                    - homeassistant.action:
                        action: media_player.play_media
                          entity_id: media_player.ai_pont
                          media_content_id: "20"
                          media_content_type: "channel"
              - button:
                  height: 100%
                  flex_grow: 1
                  widgets:
                    - label:
                        text: "ABC News\n24"
                        styles: s_rlybtn
                  checked:
                    styles: s_rlybtn_ck
                          media_content_id: "24"
              - button:
                  height: 100%
                  flex_grow: 1
                  widgets:
                    - label:
                        text: "Ten HD\n50"
                        styles: s_rlybtn
                  checked:
                    styles: s_rlybtn_ck
#                    - homeassistant.service:
                          media_content_id: "50"
              - button:
                  height: 100%
                  flex_grow: 1
#                  styles: s_rlybtn
                  widgets:
                    - label:
                        text: "Sky News\n56"
                        styles: s_rlybtn
                  checked:
                    styles: s_rlybtn_ck
                          media_content_id: "56"
#----- Container for 2nd Row Channel Buttons
        - obj:
            pad_all: 0
            bg_color: GREEN
            bg_opa: 35%
            border_opa: 50%
            align: TOP_MID
            bg_grad_dir: NONE
            width: 100%
            height: 25%
            y: 180
            layout:
              type: FLEX
              flex_flow: ROW
            text_align: CENTER
            scrollable: false
            widgets:
              - button:
                  height: 100%
                  width: 23%
                  flex_grow: 1
                  widgets:
                    - label:
                        text: "7 HD\n60"
                        styles: s_rlybtn
                  checked:
                    styles: s_rlybtn_ck
                          media_content_id: "60"
              - button:
                  height: 100%
                  width: 23%
                  flex_grow: 1
                  widgets:
                    - label:
                        text: "NBN\n80"
                        styles: s_rlybtn
                  checked:
                    styles: s_rlybtn_ck
                          media_content_id: "80"
              - button:
                  height: 100%
                  width: 23%
                  flex_grow: 1
                  widgets:
                    - label:
                        text: "9GemHd\n85"
                        styles: s_rlybtn
                  checked:
                    styles: s_rlybtn_ck
                          media_content_id: "85"
              - button:
                  height: 100%
                  width: 23%
                  flex_grow: 1
#                  styles: s_rlybtn
                  widgets:
                    - label:
                        text: "Foxtel\n111"
                        styles: s_rlybtn
                  checked:
                    styles: s_rlybtn_ck
                          media_content_id: "111"
#----- Container for Power/Volume Buttons
        - obj:
            pad_all: 0
            bg_color: GREEN
            bg_opa: 35%
            border_opa: 50%
            align: BOTTOM_MID
            bg_grad_dir: NONE
            width: 100%
            height: 25%
            y: -50
            layout:
              type: FLEX
              flex_flow: ROW
            text_align: CENTER
            scrollable: false
            widgets:
              - button:
                  height: 100%
                  flex_grow: 1
#                  styles: s_rlybtn
                  widgets:
                    - label:
                        text: "Power\nOn/Off"
                        styles: s_rlybtn
                  checked:
                    styles: s_rlybtn_ck
                        action: remote.toggle
                          entity_id: remote.ai_pont
              - button:
                  height: 100%
                  flex_grow: 2
#                  styles: s_rlybtn
                  widgets:
                    - label:
                        text: "Volume\nDown"
                        styles: s_rlybtn
                  checked:
                    styles: s_rlybtn_ck
                        action: media_player.volume_down
              - button:
                  height: 100%
                  flex_grow: 2
#                  styles: s_rlybtn
                  widgets:
                    - label:
                        text: "Volume\nUp"
                        styles: s_rlybtn
                  checked:
                    styles: s_rlybtn_ck
                        action: media_player.volume_up
The Second Image:-
lvgl:
  pages:
    - id: Right_Tv
      bg_color: BLACK
      scrollable: "OFF"
      widgets:
        - obj:
            align: TOP_MID
            widgets:
              - label:
                  align: CENTER
                  text_align: CENTER
                  text_color: 0xFFFFFF
                  text_font: roboto_18
        - obj:
            pad_all: 0
            bg_color: GREEN
            bg_opa: 35%
            border_opa: 50%
            align: TOP_MID
            bg_grad_dir: NONE
            width: 100%
            height: 50%
            y: 50
            layout:
              type: FLEX
              flex_flow: ROW_WRAP
              flex_align_cross: SPACE_EVENLY # Was STRETCH
            text_align: CENTER
            scrollable: false
            widgets:
              - button:
                  height: 48%
                  width: 23.5%
                  flex_grow: 0
#                  min_width: 23%
#                  max_width: 25%
                  widgets:
                    - label:
                        text: "ABC HD\n20"
                        styles: s_rlybtn
                  checked:
                    styles: s_rlybtn_ck
              - button:
                  height: 48%
                  width: 23.5%
                  flex_grow: 0
                  widgets:
                    - label:
                        styles: s_rlybtn
                  checked:
                    styles: s_rlybtn_ck
              - button:
                  height: 48%
                  width: 23.5%
                  flex_grow: 0
                  widgets:
                    - label:
                        text: "Ten HD\n50"
                        styles: s_rlybtn
                  checked:
                    styles: s_rlybtn_ck
              - button:
                  height: 48%
                  width: 23.5%
                  flex_grow: 0
#                  styles: s_rlybtn
                  widgets:
                    - label:
                        styles: s_rlybtn
                  checked:
                    styles: s_rlybtn_ck
              - button:
                  height: 48%
                  width: 23.5%
                  flex_grow: 0
                  widgets:
                    - label:
                        text: "7 HD\n60"
                        styles: s_rlybtn
                  checked:
                    styles: s_rlybtn_ck
              - button:
                  height: 48%
                  width: 23.5%
                  flex_grow: 0
                  widgets:
                    - label:
                        text: "NBN\n80"
                        styles: s_rlybtn
                  checked:
                    styles: s_rlybtn_ck
              - button:
                  height: 48%
                  width: 23.5%
                  flex_grow: 0
                  widgets:
                    - label:
                        text: "9GemHd\n85"
                        styles: s_rlybtn
                  checked:
                    styles: s_rlybtn_ck
              - button:
                  height: 48%
                  width: 23.5%
                  flex_grow: 0
#                  styles: s_rlybtn
                  widgets:
                    - label:
                        text: "Foxtel\n111"
                        styles: s_rlybtn
                  checked:
                    styles: s_rlybtn_ck
        - obj:
            pad_all: 0
            bg_color: GREEN
            bg_opa: 35%
            border_opa: 50%
            align: BOTTOM_MID
            bg_grad_dir: NONE
            width: 100%
            height: 25%
            y: -50
            layout:
              type: FLEX
              flex_flow: ROW
              flex_align_cross: CENTER # Was STRETCH
            text_align: CENTER
            scrollable: false
            widgets:
              - button:
                  height: 100%
                  flex_grow: 1
#                  styles: s_rlybtn
                  widgets:
                    - label:
                        styles: s_rlybtn
                  checked:
                    styles: s_rlybtn_ck
              - button:
                  height: 100%
                  flex_grow: 2
#                  styles: s_rlybtn
                  widgets:
                    - label:
                        styles: s_rlybtn
                  checked:
                    styles: s_rlybtn_ck
              - button:
                  height: 100%
                  flex_grow: 2
#                  styles: s_rlybtn
                  widgets:
                    - label:
                        text: "Volume\nUp"
                        styles: s_rlybtn
                  checked:
                    styles: s_rlybtn_ck
Any Suggestion Appreciated.
