Using Geofency for presence detection and proximity
I have Geofency configured with my home address as a tracked location and I configured the webhook. I took my dog for a walk and the location update worked great.
I have 2 questions…
  1. It doesn’t look like Geofency will constantly update my location like OwnTracks will. It appears that I have to create a tracked location in Geofency for every zone in HA. Is that correct?
  2. If I want to use the proximity sensor in HA with Geofency do I need to overlap tracked locations so Geofency updates my location for each tracked location?
Did you find out? Because I would like to know also :slight_smile:
Yes I think I did.
  1. Geofency will only track enters and exits. It will not constantly update my location.
  2. To use the proximity sensor you would need multiple geofences and I tried that but sometimes the inner ones would track before the outer ones (when I was coming home) so the proximity component was useless.
I currently use Geofency for a few automations when I leave or arrive home.
How do you make the automation?
Its not like state home or not home it think because it takes the name that you give the location in geofency???
Here is an example…
- alias: 'Close garage door on departure'
  initial_state: true
  hide_entity: false
    - platform: state
      entity_id:
        - device_tracker.981a63d3a9b648358b # John
        - device_tracker.9a2b77433e18471288 # Jill
    - service: cover.close_cover
      entity_id: cover.garage_door_opener
I also do this becomes sometimes Geofency will not fire…
- alias: 'Set John to home when iPhone is connected to WiFi'
  initial_state: true
  hide_entity: false
    - platform: state
      entity_id: binary_sensor.john_phone_ping
      to: 'on'
  condition:
    condition: template
    value_template: >
      {{ not is_state('device_tracker.981a63d3a9b648358b', 'home') }}
    service: device_tracker.see
      dev_id: '981a63d3a9b648358b'
      location_name: 'home'
Do i have to replace ‘home’ with the name of my place (zone)?
It’s named ‘thuis’ in Geofency and HA is showing that also!
Yes that is correct
Geofency is great, but any reason you don’t use HomeKit? I’ve been using it for location based automations and I think it’s great.
Its working thanks
Another question…
When i make a group and i install Geofency on my girls phone and i name home also ‘thuis’ i can use them in a group?
Because i want everything in HA. I only use HomeKit for the lights. Everything else like automation, scenes happens in HA.
Each GeoFency device had a unique id. You can add all of the GeoFency devices to a group if you like and set up automations for the group.
