I thought I’d share an integration I’ve been using for a while now. I can say Hey Google, start Netflix on the PS4 or Hey Google, start Horizon on the PS4 to wake the PS4 and start the app/game I asked for. This works whether the PS4 is in standby or in another app. It’s faster to use this to switch between Amazon and Netflix than using the remote.
Requires: IFTTT.com & ps4-waker.
Set up an IFTTT applet:
Google Assistant: Say a phrase with a text ingredient
What do you want to say?
Start $ on the PS4
What do you want the Assistant to say in response?
OK, Here's $
Webhooks: Make a web request
https://xxxx.example.org:8123/api/services/homeassistant/turn_on?api_password=yourpassword
Method
POST
Content Type (optional)
application/json
Body (optional)
{"entity_id":"script.ps4_start_x", "variables":{ "title": "{{TextField}}"} }
Note: IFTTT needs the space between the last two
characters, otherwise it’ll think it’s closing anotherTextField
In HA, add the script that IFTTT invokes, which converts the (case sensitive) text string to the Sony App ID:
# Starts the PS4 with the specified App
# use with "Start $ on the PS4"
ps4_start_x:
alias: "PS4 Start X"
sequence:
- service: shell_command.ps4_start_app
data_template:
app_id: >
{% if (title == "Netflix") %}
CUSA00127
{% elif (title == "Amazon") %}
CUSA00126
{% elif (title == "Horizon") %}
CUSA07320
{% endif %}
# Also kick the Harmony hub to turn on TV & Amp:
- service: remote.turn_on
data_template:
entity_id: remote.hubi
activity: 20685489
Finally the shell command which wakes the PS4 & starts the app:
shell_command:
ps4_start_app: 'ps4-waker start {{ app_id }} -c /home/homeassistant/.homeassistant/.ps4-wake.credentials.json'
I hope this is useful!
