I’ve been looking to add more speech messages to my daily briefing announcements. One thought that came to mind was verbalizing the current day’s Google calendar events for morning routines, and tomorrow’s events for evening routines. Each part of my briefing is separated into macros.
I’ve been looking around, and I can’t quite seem to find a relatively easy way to:
Have the automation look at the current day in the calendar
If morning, read today’s events
If evening, read tomorrow’s events
I have multiple calendars in HA, but I wanted to start off with mine. Then, if all goes well, reuse that code as a template for the other calendars.
agenda:
alias: Agenda
sequence:
- service: calendar.list_events
start_date_time: '{{ date }}'
duration:
hours: 24
minutes: 0
seconds: 0
entity_id: '{{ calendrier }}'
response_variable: evenements
- variables:
reponse: "{%- set ns = namespace(events={}) %}\n{%- for event in evenements.events\
\ %}\n {%- set default_time = \"00:00:00Z\" %}\n {%- set date_format = \"\
%Y-%m-%dT%H:%M:%S%z\" %}\n {%- set datetime_var = strptime(event.start if\
\ \"T\" in event.start else event.start + \"T\" + default_time, date_format)\
\ %}\n {%- set hour = datetime_var.strftime(\"%d/%m/%Y %H:%M\") if \"T\"\
\ in event.start else datetime_var.strftime(\"%d/%m/%Y 00:00\") %}\n {%-\
\ set ns.events = dict(ns.events, **{hour:event.summary}) %}\n{%- endfor %}\n\
{{ ns.events }}"
- stop: Success
response_variable: reponse
mode: single
icon: mdi:calendar-alert-outline
Using the olivier response in the TTS should be easy enough. Just replace the notify.mobile_app_iphone with the call to tts.google_translate_say service
Sorry, I’ve been away for a few days. Thank you for this info!
My briefing template, which covers morning and evening announcements (with some elements reading certain text based on strftime) are all in macros. In this case, how would I call the target calendar entity to list all events for the current/next day? For example:
{%- macro getSomeCalendar() -%}
{% if now().strftime('%H')|int < 12 %}
Placeholder to read todays calendar information
{% elif now().strftime('%H')|int >= 12 and now().strftime('%H')|int < 21 %}
Placeholder to read tomorrows calendar information
{% else %}
{% endif %}
{%- endmacro -%}
I’ve used the sample above with list_events and converted it now to get_events. Some modifications are built in.
I make notifications on my sony-tv and let my speakers talk, depending on boolean flags.
I always put everything in one file and put them into packages-directory.
Hope it’s useful for others
automation:
- id: 'calendar_events_announcments_get'
alias: calendar events announcments get
description: calendar_events_announcments is in the file usto_set_calendar_events.yaml
- platform: time
at: "07:00:00"
- platform: time
at: "22:00:00"
- platform: time_pattern
minutes: /30
condition: []
- if:
- condition: trigger
- condition: time
after: "05:59:00"
before: "22:35:00"
weekday:
- sun
- mon
- tue
- wed
- thu
- fri
- sat
then:
- service: script.calendar_events_announcments_agenda_get
start_date_time: "{{ (now() | as_datetime + timedelta(minutes=59)) }}"
end_date_time: "{{ (now() | as_datetime + timedelta(minutes=89)) }}"
calendrier: calendar.thomas_example_com
description: "on"
response_variable: resp_array
- if:
- condition: template
value_template: "{{ resp_array|length > 0 }}"
then:
- if:
- condition: state
entity_id: input_boolean.notify_tts_prio_medium
state: "on"
then:
- service: script.turn_on
entity_id: script.notify_tts_speak
variables:
volume: 0.5
speakers: group.tts_notify_speaker_medium
language: de-CH
message: >-
Kommende Termine: {% for key, value in resp_array.items()
{%- if key[-5:] != "00:00" %}
{{- key[-5:] + " " + value }}
{%- else %}
{{ value }}
{%- endif %}
{% endfor %}
- if:
- condition: state
entity_id: input_boolean.notify_tv_prio_medium
state: "on"
then:
- service: notify.sony
title: Kommende Termine
message: |-
{% for key, value in resp_array.items() %}
{%- else %}
{{ value }}
{%- endif %}
{% endfor %}
fontsize: medium
position: center
duration: 15
transparency: 0%
color: indigo
interrupt: 0
- if:
then:
start_date_time: "{% import 'date.jinja' as dt %} {{ dt.today() }}"
end_date_time: "{% import 'date.jinja' as dt %} {{ dt.tomorrow() }}"
description: "off"
- if:
then:
- if:
- condition: state
state: "on"
then:
variables:
volume: 0.5
language: de-CH
message: >-
Termine von heute: {% for key, value in resp_array.items()
{%- else %}
{{ value }}
{%- endif %}
{% endfor %}
- if:
- condition: state
state: "on"
then:
title: Heutige Termine
message: |-
{%- else %}
{{ value }}
{%- endif %}
{% endfor %}
fontsize: medium
position: center
duration: 15
transparency: 0%
color: indigo
interrupt: 0
- if:
then:
start_date_time: "{% import 'date.jinja' as dt %} {{ dt.tomorrow() }}"
end_date_time: "{% import 'date.jinja' as dt %} {{ dt.day_after_tomorrow() }}"
description: "off"
- if:
then:
- if:
- condition: state
state: "on"
then:
variables:
volume: 0.5
language: de-CH
message: >-
Termine von morgen: {% for key, value in
{%- else %}
{{ value }}
{%- endif %}
{% endfor %}
- if:
- condition: state
state: "on"
then:
title: Morgige Termine
message: |-
{%- else %}
{{ value }}
{%- endif %}
{% endfor %}
fontsize: medium
position: center
duration: 15
transparency: 0%
color: indigo
interrupt: 0
mode: single
script:
calendar_events_announcments_agenda_get:
alias: Calendar Events Announcments Agenda Get
sequence:
- service: calendar.get_events
entity_id: "{{ calendrier }}"
start_date_time: "{{ start_date_time }}"
end_date_time: "{{ end_date_time }}"
response_variable: eventlist
- variables:
reponse: >-
{%- set ns = namespace(events={} , itemtext="" , get_descr = 0 , get_loc = 0) %}
{%- if description == "on" %}
{%- set ns.get_descr = 1 %}
{%- endif %}
{%- if location == "on" %}
{%- set ns.get_loc = 1 %}
{%- endif %}
{%- for key, value in eventlist.items() %}
{%- for event in value.events %}
{%- set default_time = "00:00:00Z" %}
{%- set date_format = "%Y-%m-%dT%H:%M:%S%z" %}
{%- set datetime_var = strptime(event.start if "T" in event.start else event.start + "T" + default_time, date_format) %}
{%- set hour = datetime_var.strftime("%d/%m/%Y %H:%M") if "T" in event.start else datetime_var.strftime("%d/%m/%Y 00:00") %}
{%- set ns.itemtext = event.summary %}
{%- if event.location is defined and ns.get_loc == 1 %}
{%- set ns.itemtext = ns.itemtext + " ("+event.location+")" %}
{% endif -%}
{%- if event.description is defined and ns.get_descr == 1 %}
{%- set ns.itemtext = ns.itemtext + " ("+event.description+")" %}
{% endif -%}
{%- set ns.events = dict(ns.events, **{hour:ns.itemtext}) %}
{%- endfor %}
{%- endfor %}
{{ ns.events }}
- stop: Success
mode: single
I am trying to implement your automation. I’ve added the script part as a script but when I try to add the automation part as an automation I get this error message. Not sure what is exactly wrong:
Message malformed: extra keys not allowed @ data['0']
