The problème is i don’t know the content of the output, so i can’t setup the switch. I’m presuming it’s “enter” and “leave” but it doesn’t work. And nothing appears in the log with the debug node.
Firstly: how can i simulate the triggering of the zone node with HA? I’m trying changing the person state in dev tools, but nothing in node-red debug message.
Secondly: if the first question is not possible to simulate, what is the exact output of the zone node? How can i use it in the switch node, to output the switch differently if it’s a zone entering or a zone leaving?
@MoPepettes
In order to test/trigger entry or exit from a zone you will need to simulate a change of your location. You can do this by editing/changing the lat/log attributes of your person. in the Developer Tools -> State
Hint: Just change one digits in latitude or longitude to take you outside of the radius of your zone.
Changing the GPS data is not working, the debug node doesn’t say anything. Nevermind, i won’t spend hours to that, i will use event_sate node for each person.
Thanks for your help.
You can use apps that simulate you moving on the phone.
I have one called mock locations and it works great when debugging zone and proximity automations.
