Using HACS resources in Lovelace dashboard
I’m sure I’m asking something obvious, but after endless searching and reading I dare to post it here:
  • running Home Assistant 2020.12.1
  • installed HACS 1.9.0
  • downloaded Mini Media Player 1.11.0
Now I’m trying to put the Mini Media Player (or any other resource) into a Lovelace dashboard. That’s where I’m stuck.
  • putting the resources: code into the configuration.yaml file results in an error when checking the configuration file from inside Home Assistant
Component error: resources - Integration ‘resources’ not found.
  • putting the resources: code into the raw configuration file for a dashboard results in an error from the interface, pointing out that resources should be added in the configuration window now.
  • after enabling Advanced mode, I found the configuration window in Settings with the resources tab. The dialog asks me for an URL. What do I put there?
The Mini Media Player installation guide talks about /local/mini-media-player-bundle.js?v=1.11.0. If put that into the URL field, the dashboard card configuration doesn’t find the resource, resulting in an error: Error: Custom element not found: mini-media-player
In my search I read somewhere that /local is only a placeholder for the /www directory. So I tried all sorts of combinations but nothing works. The full path on my filesystem is:
/usr/share/hassio/homeassistant/www/community/mini-media-player
As I said, I’m sure this is obvious. Can you please help?
Further searching produced the solution. In the resources tab I had to put the URL:
/hacsfiles/mini-media-player/mini-media-player-bundle.js?v=1.11.0
Apparently, /hacsfiles is a virtual directory that resolves to the real place. Now it is working.
For anyone else searching, the resources tab is under Configuration, Lovelace Dashboards, Resources tab
just went through this whole rigamarole- - for anyone else searching:
/local/community is where resources are literally stored
replace that with /hacsfiles as @kongo09 stated, and as @jonkatz1 said, go to:
Configuration > Lovelace Dashboards > Resources
(this answer is redundant; I’m just combining the 2 answers)
I also spent forever trying to figure this out and these solutions are seemingly obsolete so I am adding what works now.
This is in the case of installing from HACS and using a recent enough version of HA with the new layout (as of Feb/March, I think). There is no need to edit any YAML. The Resources page can be found on the Settings / Dashboards page by clicking the three vertical dots at the top-right. No YAML required and this the only thing that worked for me after 2 hours of trying everything else.
I’ve been looking for a bit now and still can’t find it.
I’m fairly new to home assistant.
Using docker, Home Assistant 2022.7.6, Frontend 20220707.1 - latest.
No dots on Settings → Dashboard.
Was it moved?
This:
have you installed HACS? I don’t see it in your side panel.
Thanks :slight_smile:
No I haven’t installed it - I’m obviously new to this, I didn’t know it was a separate thing.
Looks like I need to find a docker image with it or create my own :frowning:
I too couldn’t find the config → lovelace dashboards → resources in the HA UI until I read this:
Basically you need to enable “Advanced Mode” under your profile (go to bottom-left corner of the HA UI). The “3 dots” in Settings → Dashboards will appear at the top-right corner. It will allow you to select “Resources”.
which basically points to this link:
http://192.168.X.XX:8123/config/lovelace/resources
(where 192.168.X.XX is your HA IP address)
