Using Hue temperature sensor value in an automation
I have a Hue external motion sensor which has a temperature sensor.
I have an automation which is basically
When time = 07:00
if temp < 5 then send a notification to my iPhone
Here is the YAML and it works.
alias: Temp msg for phone
description: ''
  - platform: time
    at: '07:00'
condition:
  - type: is_temperature
    condition: device
    device_id: 85a46df9f51c0065ba45df0f1bb220c2
    entity_id: sensor.hue_outdoor_motion_sensor_1_temperature
    domain: sensor
    below: 5
  - service: notify.mobile_app_rix_iphone11
      message: Below 5 degrees
      title: Outside temp
mode: single
I know that the sensor reports its actual temperature to HA so I was wondering if I could modify the automation it so that the Notification message included the measured/actual temperature.
I found a similar automation here
https://community.home-assistant.io/t/notify-when-temperature-crosses-specific-value/92893
with an answer by anon43302295
So I modified the YAML as shown below.
Unfortunately it doesn’t work.
When I look at “Trace timeline” I get
Stopped because an error was encountered at 9 January 2022, 07:00:02 (runtime: 0.02 seconds)
template value should be a string for dictionary value @ data['message']
I have been through the forum and the blueprints but not found why this doesn’t work (or what should be in this line of YAML.
Any suggestions gratefully received
Thank you.
# https://community.home-assistant.io/t/notify-when-temperature-crosses-specific-value/92893
description: ''
  - platform: time
    at: '07:00'
condition:
    condition: device
    domain: sensor
    below: 5
    data_template:
      message: {{ states('sensor.hue_outdoor_motion_sensor_1_temperature') }}
      title: Outside temp
mode: single
Your template needs double quotes since it is on a single line.
Thanks for your prompt (and perfect) reply.
That now works.
I could have sworn I tried that earlier… :crazy_face:
