Hi, I’m just starting to set up my home assistant and I’d like to split up the configuration at the top level entries. I had a look at the advanced documentation and it seems that include_dir_named should be the right way to create a typical conf.d directory. However it seems I can’t use that command at top level?
Eg. here is what I’d like to have in my configuration.yaml:
I did try it - that’s why I said it doesn’t work and am asking for possible workarounds.
For completeness: config_check complains:
[homeassistant.util.yaml] while scanning a simple key in "/home/homeassistant/.homeassistant/configuration.yaml", line 103, column 1 could not find expected ':'
