Note: the new packages: feature is preferred over the <<: !include method I outline below. The order of includes is opposite with packages from what I describe, so you will need to pay attention to that. Read the whole thread for more details.
Original Post:
A fellow forum user recently sent me a PM about my use of includes in ESPHome and I wanted to share my strategy with a wider audience in case it was helpful for anyone else. The advantage of the method is that if I want to make sweeping changes to my devices I can do it in one file and then Update All my nodes instead of editing 20 files individually.
This started when I wanted to drop the connectivity sensor from my switches and foreseeing other such a change in the future, I migrated to a strategy where I define my switches with two include files plus the secrets file. The first include is specific to the switch type and the second is shared across all my devices.
For example, this is what most of my switches look like:
substitutions:
# https://esphome.io/guides/configuration-types.html#substitutions
device_name: storageroomlights # hostname & entity_id
friendly_name: Storage Room Lights # Displayed in HA frontend
icon: mdi:lightbulb
# include any override YAML here
<<: !include .gosund_ks602.yaml
<<: !include .common.yaml
And that’s it! Just the substitutions section and two includes.
The order of the includes is important. The first section to get defined is the section that wins. So, for instance, I have the logger: section defined in my .common.yaml file and also in some of my switch specific includes (see example below). I need the one in the switch specific file to win, so it is before the common one. I also use this technique to override anything else defined later in the includes, which is why the includes need to be at the bottom of the file, not the top.
Here is an example of my .gosund_ks602.yaml included above:
esphome:
# https://esphome.io/components/esphome
platform: ESP8266
board: esp01_1m
logger:
baud_rate: 0 # turn off serial logging so we don't interfere with the green LED
# Uptime sensor
- platform: uptime
binary_sensor:
- platform: status
name: "${friendly_name} Connectivity"
- platform: gpio
pin:
number: GPIO0
inverted: True
on_press:
then:
- switch.toggle: relay
switch:
- platform: gpio
icon: ${icon}
pin: GPIO14
on_turn_on:
then:
- output.set_level:
level: 100%
on_turn_off:
then:
- output.turn_off: red_led
restore_mode: ALWAYS_OFF
output:
- platform: esp8266_pwm
pin:
number: GPIO16
inverted: True
status_led:
pin: # green led
number: GPIO1
inverted: True
And here is my .common.yaml file:
wifi:
# https://esphome.io/components/wifi
ssid: !secret wifi_ssid
use_address: ${device_name}.mycomain.com # I use this to add a custom domain instead of using the default .local
ap:
ssid: "${friendly_name}"
password: !secret wifi_ap_password
captive_portal:
# Enable logging
logger:
# https://esphome.io/components/logger
# Enable Home Assistant API
api:
# https://esphome.io/components/api
password: !secret api_password
ota:
# https://esphome.io/components/ota
password: !secret ota_password
# Enable Web server.
web_server:
port: 80
auth:
username: !secret web_username
password: !secret web_password
# Get the time from Home Assistant to sync the onboard real-time-clock.
time:
- platform: homeassistant
And finally, my secret.yaml file (not my real info):
wifi_ssid: MiddleEarth
wifi_password: gandalfthegray
wifi_ap_password: hardtoguess
api_password: hardtoguess
ota_password: hardtoguess
web_password: hardtoguess
web_username: admin
I also name my includes to stat with a period (.) so that they are excluded from showing up in the ESPHome dashboard. I edit them via the SMB share or a file editor in HA. I hope this is helpful!
