Using input_number as setting temperaure
Hi
In an action in my automations I am calling this service;
- service: climate.set_temperature
        entity_id: climate.baggang_gulvvarme
        temperature: "{{ states('input_number.gulvarme_stuen') | float }}"
If I test the template {{ states(‘input_number.gulvarme_stuen’) | float }} it returns 26.0. But when I call this service with this automation I get this error;
Invalid data for call_service at pos 2: expected float for dictionary value @ data[‘temperature’]
But the template is returning a float, so I cannot see where it whent wrong.
I am running HA 0.102.3 in Docker.
data: needs to be data_template:
Also everything under service: is not aligned right. Is that just some weirdness from pasting?
I use pretty much as yourself (nearly got) and Tediore corrected.
# name: Heat Temperature Set
  - alias: au_heat_temperature_set
      - platform: state
        entity_id: input_number.in_heat_temp_control_val
        data_template:
          entity_id: climate.house_heat
          temperature: "{{ states('input_number.in_heat_temp_control_val') | float }}"
Though my input_number.in_heat_temp_control_val changes throughout the day according to conditions. (door open, unoccupied, night, day and evening) 24/365
