Using input_text in lovelace configurations
Hi all,
I’m using PiotrMachowski/lovelace-xiaomi-vacuum-map-card for controlling my vacuum cleaner.
One of the options of that card is to define cleanup zones in the card’s lovelace configuration so that you can tell the vacuum to only clean a certain area.
I’m trying to define the cleanup zones using the data from an input_text entity .
The goal is to be able to define the zones in input_texts and then use them both in the vacuum card and in different automations.
I managed to do it using a custom:config-template-card which works great other than the fact that the vacuum card doesn’t update when staying focused on the dashboard (for example the location of the vacuum on the map doesn’t update until I switch to a different dashboard and then switch back).
Here’s a code example -
type: custom:config-template-card
variables:
  breakString: |
    temp => {
      var find = ' ';
      var re = new RegExp(find, 'g');
      temp = temp.replace(re, '');
      temp = temp.replace('[', '').replace(']', '').split(',')
      return temp
  ZONE_KITCHEN: states['input_text.zone_kitchen'].state
  ZONE_DINNING_ROOM: states['input_text.zone_dinning_room'].state
entities:
  - input_text.zone_kitchen
  - input_text.zone_dinning_room
card:
  type: custom:xiaomi-vacuum-map-card
  entity: vacuum.xiaomi_vacuum_cleaner
  map_source:
    camera: camera.xiaomi_cloud_map_extractor
  calibration_source:
    camera: true
  map_modes:
    - template: vacuum_clean_zone_predefined
      predefined_selections:
        - zones:
            - ${ breakString(ZONE_KITCHEN) }
          icon:
            x: 25500
            'y': 24800
        - zones:
            - ${ breakString(ZONE_DINNING_ROOM) }
          icon:
            x: 29700
            'y': 24300
    - template: vacuum_goto
Any suggestions of a different way of importing data from input_text into the lovelace configuarion?
