Using inputs in subflows
Hi. I have a problem. - I have made a subflow with one input-port called Entitet. How do i use that value in code, where i build a payload?
I have tryed this: msg.payload.data.entity_id = “${Entitet}”; - But that actualy just returns a string contaning ${Entitet} … So, there must be another way!
I assume you are talking about node red?
Holy… Yes. Sorry, i have just worked so much in Node-red theese days, that i totaly forgot that it is not Home Assistant! :slight_smile:
NP. Moved.
Looks like you’re using curly/double-quotes. That’s valid JavaScript (assuming non-curly), but just for a string, not for templating.
To do templating in JavaScript, you want to use the ticks:
msg.payload.data.entity_id = `${Entitet}`;
