Using iPhone Shortcuts for presence tracking
I have been struggling with reliably keeping track of whether my partner and I are home since the beginning of using home assistant. I have tried ESPresence, but it just wasn’t reliable enough. I tried using the iPhone app, it worked well for tracking me since I open the app regularly enough but the app on my SO’s iPhone won’t even update her battery percentage (her settings are the same as mine).
I suspect it is just iPhone keeping the app asleep in the background to save battery usage. And this is fundamentally the problem of using home assistant with an iPhone.
Recently I found a solution which has been working perfectly!
The idea came from a shortcut automation that I was using to switch my work profile on when I get to work based on my location, which always worked without any issues. So I wondered if there was a way to use a similar shortcut that could notify home assistant of my location.
I know you can run an automation to update all sensors but this also didn’t work. I did a bit of digging and found a webapp that let’s you forward a text message to a webhook.
My setup:
  • I created a dropdown helper with options such as Home, Away, Work…
  • I created an automation in home assistant where the trigger is the webhook (make sure you use the https link). This automation will then update the dropdown helper when the webhook is received.
  • In the webapp dashboard, I created a new webhook configuration with the webhook link.
  • On my iPhone, I created a new automation that sends a text message with the unique code that was given by the webapp.
So this is the workflow that I have been using:
  1. When I enter/exit a predefined (in the automation) area, a text message with a 6 digit code is sent to the number provided by the webapp.
  2. The webapp then calls the webhook.
  3. Home assistant then runs the automation, updating my location.
  4. I can then run other automations based on my location like keeping lights off when neither of us are home.
If anyone is interested, the webapp is called TextWarp, https://textwarp.app
Hopefully this will work for other people as well.
Would love to see a step-by-step of this…
Yeah I’d be happy to give a step by step. With pictures?
