Using labels for conditional cards
On my dashboard I want to show all the lights that are on so it’s easy to turn them off but I don’t want a static element there all the time. I’ve got it to work with a entity-filter card but it’s very manual and any time I add new lights I would need to edit this. I’m wondering if there is a way to use labels or something similar so I can configure it the entity-filter to be when any entity in that label is ‘on’
Here is what I have currently
title: Lights on
entities:
  - entity: light.front_door_panel_center
    type: custom:mushroom-light-card
    layout: vertical
  - entity: light.front_door_panel_top
    layout: vertical
  - entity: light.front_door_panel_bottom
    layout: vertical
  - entity: light.garage_light
    layout: vertical
  - entity: light.laundry_light_panel_bottom
    layout: vertical
  - entity: light.laundry_light_panel_top
    layout: vertical
  - entity: light.office_lights
    layout: vertical
  - entity: light.patio_lights
    layout: vertical
conditions:
  - condition: state
    state: 'on'
show_empty: false
type or paste code here
take a look at this:
there’s a example of just what you’re asking for:
type: custom:auto-entities
show_empty: false
card:
  type: glance
  title: Lights on
filter:
  include:
    - domain: light
      state: "on" # Remember that "on" and "off" are magic in yaml, and must always be quoted
      options:
        tap_action:
          action: toggle
If you need a list of lights which are ON and have a particular label:
use auto-entities as it was suggested, but define a list in a “template” option:
filter:
  template: >-
      states.light |
      selectattr('entity_id','in',label_entities('test 1')) |
      selectattr('state','==','on') |
      map(attribute='entity_id') | list
(do not use a “label” option, some people observed lags/freezes/etc)
Note that you cannot use “template”-defined filter AND “options”, you will have to define “options” inside the template. Discussion is in dedicated thread.
A word of caution: while great on its own, more than 2-3 instances of an auto-entities card will crash your browser - or at least make it INCREDIBLY SLOW. YMMV.
In my test setup I have several views for testing AE, each contains a few cards. Of course for testing things I reduced a number of displayed entries. No freezes.
I had about 24 cards, each with an AE card using a different label filter. The page was molasses.
This. Check GitHub for issues.
