Hi guys,
I’m hoping that someone can assist me here.
I currently have a drop in water tank pressure sensor in our outdoor water tank - this is working great. I’m using the following code for this:
captive_portal:
i2c:
sda: GPIO21
scl: GPIO22
scan: true
ads1115:
address: 0x48
i2c_id: bus_a
continuous_mode: off
- name: Jojo Tank Height
platform: ads1115
multiplexer: 'A0_GND'
update_interval: 60s
gain: 4.096
unit_of_measurement: "metres"
icon: "mdi:gauge"
# accuracy_decimals: 3
filters:
- median:
window_size: 200
send_every: 10
send_first_at: 4
- calibrate_linear:
- 0.480 -> 0
- 1.0232 -> 1.545
name: Jojo Tank Volume
unit_of_measurement: "litres"
lambda: |-
return 3.14159265 * 0.71 * 0.71 * id(tank_height).state * 1000;
name: Jojo Tank Percentage
unit_of_measurement: "%"
accuracy_decimals: 0
lambda: |-
return (id(tank_height).state) / 1.545 * 100;
- platform: wifi_signal
name: "Jojo Volume WiFi Signal Sensor"
I’d like to add another ESP8266/ESP32 to live in our kitchen, connected to a LED bar (containing 10 LED’s) with each LED representing 0%, 10% 20%… all the way up to 100% - basically 1 bar per 10% to visually display the water percentage in the tank.
Here is the LED bar that I have on order: LED Bar
Is anyone able to kindly assist me with a basic code to make this happen?
