I have given up using DuckDNS as I could not get it working so uninstalled it and am installing Lets’s Encrypt add-on and using my routers (TP-Link) built in Dydns service.
I have the routers DyDNS setup and the Let’s Encript add on set up (log file shows no errors).
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
cont-init: info: running /etc/cont-init.d/file-structure.sh
cont-init: info: /etc/cont-init.d/file-structure.sh exited 0
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
services-up: info: copying legacy longrun lets-encrypt (no readiness notification)
s6-rc: info: service legacy-services successfully started
[19:25:03] INFO: Selected http verification
[19:25:03] INFO: Detecting existing certificate type for zerodog.tplinkdns.com
Saving debug log to /var/log/letsencrypt/letsencrypt.log
[19:25:06] INFO: No certificate found - using 'ecdsa' key type.
Account registered.
Requesting a certificate for XXXX.tplinkdns.com
Successfully received certificate.
Certificate is saved at: /data/letsencrypt/live/XXXX.tplinkdns.com/fullchain.pem
Key is saved at: /data/letsencrypt/live/XXXX.tplinkdns.com/privkey.pem
This certificate expires on 2025-02-16.
These files will be updated when the certificate renews.
NEXT STEPS:
- The certificate will need to be renewed before it expires. Certbot can automatically renew the certificate in the background, but you may need to take steps to enable that functionality. See https://certbot.org/renewal-setup for instructions.
If you like Certbot, please consider supporting our work by:
* Donating to ISRG / Let's Encrypt: https://letsencrypt.org/donate
* Donating to EFF: https://eff.org/donate-le
s6-rc: info: service legacy-services: stopping
s6-rc: info: service legacy-services successfully stopped
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
I have also changed the domain in ‘NGINX Home Assistant SSL proxy’ and log file looks good. I then restarted HA.
But the domain is timing out (ERR_CONNECTION_TIMED_OUT).
