Using Let's Encrypt Certificate From Asus Router for SSL
Hi everyone,
If you are like me have Asus router with Dynamic DNS and Let’s encrypt cert that you want to use for HA,
than you can follow this guide for configuration and blueprints to make it happen. Also it will renew the cert automatically. Setup one time and forget about it!
homeassistant_tools/ssl_cert_from_asus/README.md at main · bullmastiffo/homeassistant_tools (github.com)
P.S. I’ve done all the work before I’ve discovered this add-on Home Assistant Add-on: home-assistant-ssl-from-asus-router - Installation / Home Assistant OS - Home Assistant Community
In anyway I want to share my work as it has some differences:
  • My approach uses different technic to fetch SSL cert, not via SSH but via web GET request, so you don’t have to enable SSH on the router and don’t have to know where key or cert files are on the router.
  • And there’s automation to renew the certificate!
Thank you for this, works like a charm. At least the initial setup was all good. Will see ~90 days later if automatic renewal will really happens, or not.
If I can suggest just 1-2 small things for your documentation:
1, At step3, you have a line with only ‘ssh’, mkdir is missing from there
2, Also at step3, after ssh to the root user, please add a note if a successful login occurs, one must logout from the root account before continuing with the cp command
3, I don’t know if it a general behaviour for asus routers, or not, bot worth a note somewhere: if the router allows only one login at a time, the certificate download won’t be successful if there is an already existing active login. Which is most likely a valid condition, when one just obtained the authorization key, and left the browser as-is.
Thank you for the feedback, I’ve created an item to improve the doc, will do it later, otherwise feel free to publish a pull request with update.
I tried to run the automation manually, seemed to work, but I am curious to check out in January as well :slight_smile:
Thank you so much for this exactly what I needed. I think I managed to get everything configured correctly but when I run the script I get:
stdout: ""
stderr: "Permission denied, please try again.\r\nPermission denied, please try again.\r\nroot@localhost: Permission denied (publickey,password)."
returncode: 255
So I do something wrong. I’ve checked certs and more but I can’t find a solution (after 5 hours) So hopefully someone can point me in the right direction. I use an ASUS XT8 and can access it over 10.0.1.1 and use all links ink download script in the scriptfile. I don’t use SSL so I don’t add a port to the url. RUnning homeassistant in docker on debian 12. I been testing with changing permission just to see where it goes wrong but without success. I’ve compared keys as well but no luck. Anyone have an idea of what to do?
I’ve manually downloaded cert and added it to SLL to be able to start NGINX, that works.
Most likely problems due to misconfigured SSH credentials (step 3).
shell script execution can’t access your SSH server.
Also RUnning homeassistant in docker on debian 12 for this part, maybe ssh add-on runs somehow different and on different port, because maybe there sohuld be IP of your HA instance in the docker.
Thanks for this post. Buying a NUC and setting up HA has been a brain workout for me and I am thankful for as I believe it’s helping me get over my stroke and raise my confidence when I get back to work.
With the help of Bullmastifo and ahhoj it gotten to the point on step 3 where I enter “ssh-keygen”. I am promted
Generating public/private ed25519 key pair.
Enter file in which to save the key (/root/.ssh/id_ed25519):
I have no idea what id_rsa file and folder it is referring to from the next copy instructions. Thank you guys very much. I hate asking silly questions but I am happy to have gotten this far without bothering anyone.
I enjoyed watching even outdated videos and figuring out the changes to get things as simple as terminal working via generated key. Took me even longer to make an SSL page due to a router that recently died and some forgotten settings.
I guess id_rsa is the name of the output key file it’s generating. In your case, looks like the file will be /root/.ssh/id_ed25519.
Hello, I’ll give an update 4 months after asking for help.
I after a bit of research and according to ssh.com, I found out that the command “ssh-keygen -t rsa” will give the results as in the instruction using rsa as it stated in the instruction instead of ed25519 as it now defaults to. There was some errors in the instructions but bullmastiffo had updated instructions which were later committed to the instructions.
I am up to step 8 where I need to Run imported shell_command to populate the cert for the first time. I get the error “stdout: “” stderr: Host key verification failed. returncode: 255” 100 percent of the time. I’ve tried on and off for 4 months and still am stuck here.
At step (3) there’s a comment for script:
ssh root@localhost -i id_rsa # at this step it will suggest to add host as known, press yes
so do it manually once and let the host to be added as known. but use your type instead of id_rsa
I now remember that at this point I kept getting a "permission Denied, please type again password error. I completely forgot how I ended up getting past that but that took me about a week. I know that I have the ssh and terminal program setup to both accept password and the other way where it uses an encrypted key or something. I truly thank you for all the help but I’ve realized that this is no task for a non Linux user. At least it is far out of my skill set to get this working. I thank you for all your work.
I was never able to get this working but was fine with refreshing ever 3 months. About a week ago, the ddns stopped working. I tried for a few days but it would just error out. I was able to partially register it using the app but just got sick of it. I am annoyed that I haven’t been use the duckdns option that is so heavily recommended by people with HA. It literally does everything without the downsides or renewal or hassle. Now that Asus DDNS went down whether temporarily or permanent, I have much more options for a replacement router when that happens. This was one of my main routers for replacing my past router with this new one.
