Using Local Calendar to switch on the heating
I hope someone can help me with a basic automation using local calendar and my trv switches. I am trying to turn my heating on at a certain time.
I have configured the event in local calendar. I can run the automation using Traces/Run and the trv’s switch on. However leaving the automation to run by itself does not work. I can see the local calendar event become active in the logbook but the automation does start.
This is my yaml file for the automation.
Help much appreciated as going around in circles with this.
alias: Switch on Central Heating at 1700
description: ""
  - platform: calendar
    event: start
    entity_id: calendar.heating
condition:
  - condition: template
    value_template: "value_template: \"{{ 'PM heating on' in trigger.calendar_event.summary }}\""
  - service: climate.set_hvac_mode
      hvac_mode: heat
      device_id:
        - afac8579a578a9bb35aa37137708c2b4
        - aa7394145e113233963d890831e64171
        - 74fccde01387612615df506ca42f2e6c
        - d6d78fb1120b69a7c8a52b057dc66a72
        - 68f47d5ce09cb8a25af5ae5efd1d23f7
mode: single
condition:
    value_template: "{{ 'PM heating on' in trigger.calendar_event.summary }}"
That command only executes the automation’s actions. It doesn’t exercise the trigger or condition so it didn’t run your automation’s faulty Template Condition.
@123 thanks for your reply, I made the changes but I am still having issues.
Is it best to create automations in the UI or direct into automations.yaml?
I see the condition in the UI as this
In the UI with edit in yaml:
condition: template
|In automations.yaml I see this:
- id: '1701114272029'
  description: ''
    event: start
    offset: 0:0:0
  condition:
      hvac_mode: heat
      device_id:
  mode: single
I am now very confused as when I look at TRACES and Automations.yaml again I see changes to the value_template that were not made by me…
I am not sure what is happening.
condition: template
value_template: '"{{ ''PM heating on'' in trigger.calendar_event.summary }}"'
Automations.yaml
  description: ''
    event: start
    offset: 0:0:0
  condition:
    value_template: '{{ ''PM heating on'' in trigger.calendar_event.summary }}'
      hvac_mode: heat
      device_id:
  mode: single
The Automation Editor’s preference is to a single quote and double single quotes (not the same as a double quote).
In other words, it uses:
instead of:
So when you manually enter a double quote character, upon saving the automation the Automation Editor will convert it conform to its formatting rules.
What are the issues?
Currently, your automation has a Calendar Trigger that triggers whenever it detects the start of a scheduled calendar event. It then checks if the event’s summary contains the string PM heating on. If it doesn’t then it ends. If it does, it sets several devices to heat mode.
Be advised that if you are testing it by adding a calendar event that occurs less than 15 minutes in the future, it is likely that it won’t be detected (due to the polling frequency for calendar events).
I have a similar automation that has a calendar input, plus a temp check to turn on a heater.
Maybe you can check your formatting vs mine.
alias: Heat Barn
description: ""
  - platform: time
    at: "06:45:00"
condition:
    value_template: "{{ state_attr('weather.pirateweather', 'temperature') < 40}}"
    alias: Check Temperature
  - if:
      - condition: or
        conditions:
            value_template: >-
              {{ ('No School' in state_attr('calendar.bartley_events',
              'message')) }}
            alias: Check No School
          - condition: time
            weekday:
              - sat
              - sun
    then:
      - delay:
          hours: 1
          minutes: 15
          seconds: 0
          milliseconds: 0
      - type: turn_on
        device_id: 47357ad8eb549596fc5ab50f1c2a3164
        entity_id: acabf96a71858d8335d1b3782886c807
        domain: switch
      - delay:
          hours: 1
          minutes: 30
          seconds: 0
          milliseconds: 0
      - type: turn_off
        domain: switch
    else:
      - type: turn_on
        domain: switch
      - delay:
          hours: 1
          minutes: 30
          seconds: 0
          milliseconds: 0
      - type: turn_off
        domain: switch
mode: single
FYI
You replied to my post but I’m not the topic’s author (mauriceatkinson).
@mauriceatkinson
If you don’t care for how the Automation Editor automatically reformats things, the other option is to use a text editor and keep your automations separate from those created using the Automation Editor. However you must become comfortable with YAML to go that route.
