Using LSC 3203632.1 RGBIC+CCTIC Ledstrip with ESPHome
Last week, I purchased the LSC Smart Ledstrip RGBIC+CCTIC (3203632.1) from Action.
This LED strip features addressable RGB and addressable CCT LEDs. The strip can be controlled with the Tuya Smart Life app, which allows for effects, colors per segment, etc. However, in Home Assistant, the strip is discovered as a single device, with no options for segments or individual LED control. I want to avoid relying on the cloud and Tuya; instead, I’d like to control this strip using WLED or ESPHome. I started researching the possibilities.
Specs RGBIC + CCTIC controller
The device is based on a BK7231N chip. It has 25 segments of approximately 20 cm, making the total length 5 meters. The controller is powered by a 24V 1A power supply. Each 20 cm segment contains 6 RGB, 6 CW, and 6 WW LEDs. In the software, each segment (20 cm, 6 LEDs) is treated as a single LED. Each segment has two control chips, specifically GZX16703. On the controller’s PCB, the type is labeled as PCB_475P1-v1.0. The PCB also has pins labeled C and W, but these do not connect to the LED strip.
Cloudcutter
I have substantial experience with Tuya Cloudcutter and even wrote a step-by-step guide on my blog. Unfortunately, this device cannot be flashed with Cloudcutter because the firmware is patched by Tuya. The chip is a BK7231N running Tuya firmware version 1.0.2.
Flashen via UART
Through a topic on Elektroda, I found that someone had successfully flashed OpenBeken onto the device. This has to be done via UART due to the patched Tuya firmware.
I connected my UART USB to the following pins:
USB UART Beken 7231N
3.3V 3.3V
TX 1RX
RX 1TX
GND GNG
Using the BK7231 GUI Flash Tool, I connected to the BK7231N. To be safe, I made a backup of the Tuya firmware in case I want to revert.
After flashing the OpenBeken software, I performed an OTA update to ESPHome.
Flashing to ESPHome
I first created a new device in ESPHome Compiler based on the generic-bk7231n-qfn32-tuya board. I downloaded the ESPHome firmware as a Beken OTA file and renamed it to “OpenBK7231N_esphome.rbl” to avoid an invalid firmware error.
The flashing was successful, and the new device was discovered by Home Assistant.
Adjusting ESPHome YAML
Finding the correct configuration was trial and error. Initially, the LED strip didn’t turn on at all. During my research, I remembered a pin needed to be activated to provide 24V to the strip. After scrolling through the Elektroda topic, I found that P8 was responsible for this.
After adding the GPIO switch to the ESPHome YAML, the LED strip turned on. YAY!
switch:
  - platform: gpio
    pin: P8
Adjusting Colors
This turned out to be tricky. Setting is_wrgb or is_rgbw to true caused the strip to display random colors instead of the selected ones in Home Assistant’s color picker. These features worked in the original Tuya app, so I investigated further.
Through trial and error, I discovered that Tuya designed the strip so that CW and WW LEDs are addressed on odd numbers, while RGB LEDs are addressed on even led numbers. In the YAML configuration, you must omit is_wrgb or is_rgbw and let Home Assistant treat it as an RGB strip. While functional, this is not an elegant solution, so I’d like to modify parts of the code.
  - platform: beken_spi_led_strip
    rgb_order: BRG
    pin: P16
    num_leds: 25
    chipset: SM16703
    on_turn_on:
      - switch.turn_on: onoff
    on_turn_off:
      - switch.turn_off: onoff
Now I Need Help!
Using light partitions, I can test the correct colors and white values for separate segments. RGB LEDs work as expected, but for white values, you must select Red for Cool White and Green for Warm White in the color picker.
  - platform: partition
    segments:
      # This is the first module RGB leds
      - id: RGBIC_CCTIC_ledstrip
        to: 0
    segments:
      # This is the first module CW/WW leds.
      # Controls in HA are: Red = Cool White, Green = Warm White
        to: 1
    segments:
      # This is the second module RGB leds
        to: 2
    segments:
      # This is the second module CW/WW leds
        to: 3
TL;DR:
Desired changes/additions to the beken_spi_led_strip component:
  • Support for separate CW/WW IC chips so CW/WW LEDs don’t need to be controlled with red and green.
Desired changes/additions to the light.partition component:
  • Support for arrays of LED numbers, allowing you to create segments like 0, 2, 4, 6, 8, etc., and 1, 3, 5, 7, 9, etc., to set colors or white values properly across multiple segments.
Who can help me with this, or where can I submit an issue/feature request?
Posted a ESPHome feature request:
Support for RGBIC + CCTIC ledstrips like LCS 3203632.1 · Issue #2991 · esphome/feature-requests
Complete Work In Progress code ESPHome
esphome:
  friendly_name: test-beken
bk72xx:
  board: generic-bk7231n-qfn32-tuya
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: "c1HWBG3tbftOhAwajKUroWEcveMUFx6MQQHqDDDUNFs="
ota:
  - platform: esphome
    password: "6cd21eea0c30fa70b86209a14db920da"
wifi:
  ssid: !secret wifi_ssid
  ap:
captive_portal:
web_server:
light:
    rgb_order: BRG
    pin: P16
    num_leds: 25
    chipset: SM16703
    on_turn_on:
    on_turn_off:
    segments:
        to: 0
    segments:
      # This is the first module CW/WW leds. Controls in HA are: Red = Cool White, Green = Warm White
        to: 1
    segments:
        to: 2
    segments:
        to: 3
switch:
  - platform: gpio
    pin: P8
good job so far! I bought this one blindly yesterday, and unfortunately no openbeken profile for it yet so i ended up here.
did you make any progress since last post?
Is you config in its current state usuable as a warmwhite ledstrip?
Hi, me and chatgpt made a custom component. This works for me as RGB+CCT:
esphome:
  friendly_name: Ledstrip
bk72xx:
# Enable logging
logger:
api:
ota:
  - platform: esphome
wifi:
  ap:
external_components:
  - source:
      type: git
      url: https://github.com/arhein123/esphome
      ref: dev
    components: [beken_spi_led_strip_2]
captive_portal:
web_server:
light:
  # Main LED Strip Configuration
  - platform: beken_spi_led_strip_2
    pin: 16
    num_leds: 50
    chipset: SM16703
    is_rgbww: true
    on_turn_on:
    on_turn_off:
switch:
  - platform: gpio
    pin: P8
binary_sensor:
  - platform: gpio
    pin:
      number: P9
      mode: INPUT_PULLUP
    internal: true
  - platform: gpio
    pin:
      number: P24
      mode: INPUT_PULLUP
    internal: true
  - platform: gpio
    pin:
      number: P28
      mode: INPUT_PULLUP
    internal: true
remote_receiver:
  pin:
    number: P26
    inverted: true
  dump: all
Could you please explain this a bit more? You got it fully working with cool/warm white AND RGB colors?
Yes, this is working.
but I’m no programmer, this is more a proof of concept. I thought it would be a fun experiment to see if i could get it working together with ChatGPT. And the basis is working.
The esphome config for the IR receiver and buttons are also present, but not used.
Cool! Taking mine out of storage and try this out. Thx! I’ll report back here once I got your configure working as well
Mine is working as well using your config.
Selectinga colour is cumbersome with 3 sliders but it’s better then nothing.
Let’s see how the will develop further here and on elektroda.pl where the main forum vor beken chips is.
Thx for the config.
Thanks for your replies and nice to see it is working for you.
In the meantime I have created a working solution also.
Below the working esphome yaml without custom components.
I’m able to control RGB and CCT as 1 light and control all seperate modules per compartment (9 in total) of my cabinet. You can delete them from the yaml if you don’t need them.
esphome:
  friendly_name: Buffetkast
bk72xx:
# Enable logging
logger:
api:
  encryption:
ota:
  - platform: esphome
wifi:
  ap:
captive_portal:
web_server:
power_supply:
    pin: P8
light:
    rgb_order: BRG
    pin: P16
    num_leds: 37
    chipset: SM16703
    power_supply: led_power
    internal: true
### ALL RGB LEDS IN 1 LIGHT
    effects:
     - random:
     - pulse:
     - strobe:
     - flicker:
     - addressable_rainbow:
     - addressable_color_wipe:
     - addressable_scan:
     - addressable_twinkle:
     - addressable_random_twinkle:
     - addressable_fireworks:
    segments:
      # RGB LEDS AT EVEN ADDRESSES
        to: 0
        to: 2
        to: 4
        to: 6
        to: 8
        to: 10
        to: 12
        to: 14
        to: 16
        to: 18
        to: 20
        to: 22
        to: 24
        to: 26
        to: 28
        to: 30
        to: 32
        to: 34
        to: 36
## ALL CCT LEDS IN 1 LIGHT
    segments:
      # CCT LEDS AT ODD ADDRESSES
      # RED CHANNEL = WARM WHITE
      # GREEN CHANNEL = COLD WHITE
        to: 1
        to: 3
        to: 5
        to: 7
        to: 9
        to: 11
        to: 13
        to: 15
        to: 17
        to: 19
        to: 21
        to: 23
        to: 25
        to: 27
        to: 29
        to: 31
        to: 33
        to: 35
#### ALL CCT LEDS PER CABINET COMPARTMENT
    name:  CTT Boven Links
    segments:
      # CTT CABINET TOP LEFT
        to: 1
        to: 3
    name:  CTT Boven Midden
    segments:
      # CTT CABINET TOP MID
        to: 5
        to: 7
    name:  CTT Boven Rechts
    segments:
      # CTT CABINET TOP RIGHT
        to: 9
        to: 11
    name:  CTT Midden Links
    segments:
      # CTT CABINET MID LEFT
        to: 13
        to: 15
    name:  CTT Midden Midden
    segments:
      # CTT CABINET MID MID
        to: 17
        to: 19
    name:  CTT Midden Rechts
    segments:
      # CTT CABINET MID RIGHT
        to: 21
        to: 23
    name:  CTT Onder Links
    segments:
      # CTT CABINET BOTTOM LEFT
        to: 25
        to: 27
    name:  CTT Onder Midden
    segments:
      # CTT CABINET BOTTOM MID
        to: 29
        to: 31
    name:  CTT Onder Rechts
    segments:
      # CTT CABINET BOTTOM RIGHT
        to: 33
        to: 35
#### ALL RGB LEDS PER CABINET COMPARTMENT
    name:  RGB Boven Links
    segments:
    # RGB CABINET TOP LEFT
      to: 0
      to: 2
    name:  RGB Boven Midden
    segments:
    # RGB CABINET TOP MID
      to: 4
      to: 6
    name:  RGB Boven Rechts
    segments:
    # RGB CABINET TOP RIGHT
      to: 8
      to: 10
    name:  RGB Midden Links
    segments:
    # RGB CABINET MID LEFT
      to: 12
      to: 14
    name:  RGB Midden Midden
    segments:
    # RGB CABINET MID MID
      to: 16
      to: 18
    name:  RGB Midden Rechts
    segments:
    # RGB CABINET MID RIGHT
      to: 20
      to: 22
    name:  RGB Onder Links
    segments:
    # RGB CABINET BOTTOM LEFT
      to: 24
      to: 26
    name:  RGB Onder Midden
    segments:
    # RGB CABINET BOTTOM MID
      to: 28
      to: 30
    name:  RGB Onder Rechts
    segments:
    # RGB CABINET BOTTOM RIGHT
      to: 32
      to: 34
As you can see you can add multiple led addresses to a segment. This was unclear for me in the docs so I provided a example for the docs and did a pull request.
The only thing is: you still have to control WW en CW with the colors red and green…
Thats quite the progress! i bookmarked this page to follow the updates. In the meantime i managed to repair the zigbee strip by replacing the blown 24v psu, so this strip is in storage for now until i have a nice use for it.
please also post your findings on elektroda which is pretty much the home of openbeken, so people can build upon your findings.
I edited your config so its more baseline without your removed leds and cupboard configs. It just makes 2 HA light entities instead of many.
Also now all strip parts are addressable instead of per 2.
This should work out of the box for a new uncut trip.
esphome:
  friendly_name: Lsc 3203632-1
bk72xx:
# Enable logging
logger:
api:
  encryption:
    key: "REDACTED"
ota:
  - platform: esphome
    password: "REDACTED"
wifi:
  ap:
    ssid: "REDACTED"
captive_portal:
web_server:
power_supply:
    pin: P8
light:
    rgb_order: BRG
    pin: P16
    num_leds: 50
    chipset: SM16703
    internal: true
    effects:
     - random:
     - pulse:
     - strobe:
     - flicker:
     - addressable_scan:
    segments:
        to: 0
        to: 1
        to: 2
        to: 3
        to: 4
        to: 5
        to: 6
        to: 7
        to: 8
        to: 9
        to: 10
        to: 11
        to: 12
        to: 13
        to: 14
        to: 15
        to: 16
        to: 17
        to: 18
        to: 19
        to: 20
        to: 21
        to: 22
        to: 23
        to: 24
        to: 25
        to: 26
        to: 27
        to: 28
        to: 29
        to: 30
        to: 31
        to: 32
        to: 33
        to: 34
        to: 35
        to: 36
        to: 37
        to: 38
        to: 39
        to: 40
        to: 41
        to: 42
        to: 43
        to: 44
        to: 45
        to: 46
        to: 47
        to: 48
        to: 49
    segments:
        to: 49
@fuzzyduck thanks for you effort!
In your code the addresses will not work for controlling rgb and cct only. Like in my code you have to specify only odd and even leds in the segments.
And I made a mistake myself, the blue channel is connected to de CW leds. I checked this this morning.
So the standard code for this LSC 3203632.1 ledstrip will be:
esphome:
bk72xx:
# Enable logging
logger:
api:
  encryption:
    key: "REDACTED"
ota:
  - platform: esphome
wifi:
  ap:
    ssid: "REDACTED"
captive_portal:
web_server:
power_supply:
    pin: P8
light:
    rgb_order: BRG
    pin: P16
    num_leds: 50
    chipset: SM16703
    internal: true
    effects:
     - random:
     - pulse:
     - strobe:
     - flicker:
     - addressable_scan:
    segments:
        to: 0
        to: 2
        to: 4
        to: 6
        to: 8
        to: 10
        to: 12
        to: 14
        to: 16
        to: 18
        to: 20
        to: 22
        to: 24
        to: 26
        to: 28
        to: 30
        to: 32
        to: 34
        to: 36
        to: 38
        to: 40
        to: 42
        to: 44
        to: 46
        to: 48
    segments:
      # BLUE CHANNEL = COLD WHITE
        to: 1
        to: 3
        to: 5
        to: 7
        to: 9
        to: 11
        to: 13
        to: 15
        to: 17
        to: 19
        to: 21
        to: 23
        to: 25
        to: 27
        to: 29
        to: 31
        to: 33
        to: 35
        to: 37
        to: 39
        to: 41
        to: 43
        to: 45
        to: 47
        to: 49
Hey, you are right about the odd/even, but please add the remaining numbers until 48/48 for even and 49/49 to odd. Then we got a fully working template for an uncut strip (with weird white channels)
Good idea. I’ve updated the code in my above post
Hi, i have left the custom library and continued to get al the features of the LED strip working. I have created a config with IR remote and MIC working. there is also a custom light effect that works with the microphone:
esphome:
  friendly_name: 5m_ledstrip
bk72xx:
  framework:
    version: dev
logger:
  level: INFO
api:
ota:
  - platform: esphome
web_server:
wifi:
  ap:
captive_portal:
globals:
  - id: active_effect
    type: int
    restore_value: yes
    initial_value: '0'
output:
    type: float
    power_supply: powersupply
    zero_means_zero: True
    write_action:
      lambda: |-
        auto call = id(cw_ww_partition).turn_on();
        call.set_red(state);
        call.set_transition_length(100);
        call.perform();
    type: float
    write_action:
      lambda: |-
        call.set_blue(state);
        call.perform();
power_supply:
  - id: powersupply
    pin: 8
light:
  - platform: cwww
    cold_white: output_component2
    warm_white: output_component1
    cold_white_color_temperature: 6500 K
    warm_white_color_temperature: 2700 K
    gamma_correct: 1
    constant_brightness: False
    on_turn_on:
      then:
        - light.turn_off: rgb_partition
    pin: 16
    num_leds: 50
    chipset: SM16703
    rgb_order: BRG
    internal: true
    default_transition_length: 0.5s
    segments:
      - id: rgbic_cctic_ledstrip
        to: 0
        to: 2
        to: 4
        to: 6
        to: 8
        to: 10
        to: 12
        to: 14
        to: 16
        to: 18
        to: 20
        to: 22
        to: 24
        to: 26
        to: 28
        to: 30
        to: 32
        to: 34
        to: 36
        to: 38
        to: 40
        to: 42
        to: 44
        to: 46
        to: 48
    effects:
     - random:
     - pulse:
     - strobe:
     - flicker:
     - addressable_scan:
     - addressable_lambda:
         name: "Sound Rainbow Effect"
         update_interval: 50ms
         lambda: |-
           float mic_level = id(mic).state;
           float normalized = min(mic_level, 1.0);
           int max_distance = floor(normalized * 12.0);  // 12 is max afstand vanaf het midden
           for(int i = 0; i < it.size(); i++) {
             int distance = abs(i - 12);
             if(distance <= max_distance) {
               // Bereken de hue op basis van de LED positie voor een regenboog effect
               float hue = (float)i / 25.0 * 360.0;
               // Handmatige HSV naar RGB conversie
               float h = hue;
               float s = 1.0;
               float v = 1.0;
               int sector = ((int)floor(h / 60.0)) % 6;
               float f = (h / 60.0) - floor(h / 60.0);
               float p = v * (1.0 - s);
               float q = v * (1.0 - f * s);
               float t = v * (1.0 - (1.0 - f) * s);
               float r, g, b;
               if (sector == 0) { r = v; g = t; b = p; }
               else if (sector == 1) { r = q; g = v; b = p; }
               else if (sector == 2) { r = p; g = v; b = t; }
               else if (sector == 3) { r = p; g = q; b = v; }
               else if (sector == 4) { r = t; g = p; b = v; }
               else { r = v; g = p; b = q; }
               uint8_t red = (uint8_t)(r * 255);
               uint8_t green = (uint8_t)(g * 255);
               uint8_t blue = (uint8_t)(b * 255);
               it[i] = Color(red, green, blue);
             } else {
               it[i] = Color(0, 0, 0);  // LED uit
    on_turn_on:
      then:
        - light.turn_off: cw_ww
    internal: True
    segments:
        to: 1
        to: 3
        to: 5
        to: 7
        to: 9
        to: 11
        to: 13
        to: 15
        to: 17
        to: 19
        to: 21
        to: 23
        to: 25
        to: 27
        to: 29
        to: 31
        to: 33
        to: 35
        to: 37
        to: 39
        to: 41
        to: 43
        to: 45
        to: 47
        to: 49
remote_receiver:
  pin:
    number: P26
    inverted: true
  dump: nec
  - platform: adc
    pin: ADC3
    internal: true
script:
  # Timer scripts to turn off RGB and White after specific durations
  - id: timer_1h
    mode: single
    then:
      - delay: 1h
      - light.turn_off:
      - light.turn_off:
  - id: timer_2h
    mode: single
    then:
      - delay: 2h
      - light.turn_off:
      - light.turn_off:
  - id: timer_3h
    mode: single
    then:
      - delay: 3h
      - light.turn_off:
      - light.turn_off:
binary_sensor:
  # Pushbutton 1
  - platform: gpio
    pin:
      number: P9
      mode: INPUT_PULLUP
    internal: true
  # Pushbutton 2
  - platform: gpio
    pin:
      number: P24
      mode: INPUT_PULLUP
    internal: true
  # Pushbutton 3
  - platform: gpio
    pin:
      number: P28
      mode: INPUT_PULLUP
    internal: true
  # Button 1: Brightness RGB Up
  - platform: remote_receiver
    name: "Brightness RGB Up"
    internal: true
    nec:
      address: 0xEF00
      command: 0xE31C
    on_press:
      - if:
          condition:
            - light.is_on: cw_ww
          then:
            - light.dim_relative:
                relative_brightness: 10%
          else:
                relative_brightness: 0%
  # Button 2: Brightness RGB Down
    name: "Brightness RGB Down"
    internal: true
    nec:
      address: 0xEF00
      command: 0xE21D
    on_press:
      - if:
          condition:
          then:
                relative_brightness: -10%
          else:
  # Button 3: OFF
    internal: true
    nec:
      address: 0xEF00
      command: 0xE11E
    on_press:
      - light.turn_off:
      - light.turn_off:
  # Button 4: ON
    internal: true
    nec:
      address: 0xEF00
      command: 0xE01F
    on_press:
      - light.turn_on:
  # Button 5: RGB Red
    internal: true
    nec:
      address: 0xEF00
      command: 0xFF00
    on_press:
      - light.turn_on:
          red: 1.0
          green: 0.0
          blue: 0.0
  # Button 6: RGB Green
    internal: true
    nec:
      address: 0xEF00
      command: 0xFE01
    on_press:
      - light.turn_on:
          red: 0.0
          green: 1.0
          blue: 0.0
  # Button 7: RGB Blue
    internal: true
    nec:
      address: 0xEF00
      command: 0xFD02
    on_press:
      - light.turn_on:
          red: 0.0
          green: 0.0
          blue: 1.0
  # Button 8: Timer 1H
    internal: true
    nec:
      address: 0xEF00
      command: 0xFC03
    on_press:
      - script.execute: timer_1h
  # Button 9: Orange
    internal: true
    nec:
      address: 0xEF00
      command: 0xFB04
    on_press:
      - light.turn_on:
          red: 1.0
          green: 0.5
          blue: 0.0
  # Button 10: Light Green
    internal: true
    nec:
      address: 0xEF00
      command: 0xFA05
    on_press:
      - light.turn_on:
          red: 0.5
          green: 1.0
          blue: 0.0
  # Button 11: Light Blue
    internal: true
    nec:
      address: 0xEF00
      command: 0xF906
    on_press:
      - light.turn_on:
          red: 0.0
          green: 1.0
          blue: 1.0
  # Button 12: Timer 2H
    internal: true
    nec:
      address: 0xEF00
      command: 0xF807
    on_press:
      - script.execute: timer_2h
  # Button 13: Yellow
    internal: true
    nec:
      address: 0xEF00
      command: 0xF708
    on_press:
      - light.turn_on:
          red: 1.0
          green: 1.0
          blue: 0.0
  # Button 14: Dark Green
    internal: true
    nec:
      address: 0xEF00
      command: 0xF609
    on_press:
      - light.turn_on:
          red: 0.0
          green: 0.5
          blue: 0.0
  # Button 15: Purple
    internal: true
    nec:
      address: 0xEF00
      command: 0xF50A
    on_press:
      - light.turn_on:
          red: 0.5
          green: 0.0
          blue: 0.5
  # Button 16: Timer 3H
    internal: true
    nec:
      address: 0xEF00
      command: 0xF40B
    on_press:
      - script.execute: timer_3h
  # Button 17: WW (Warm White)
    name: "WW (Warm Wit)"
    internal: true
    nec:
      address: 0xEF00
      command: 0xF30C
    on_press:
      - light.turn_on:
          warm_white : 1.0
          cold_white: 0.0
  # Button 19: CW (Neutral White)
    name: "NW (Neutral White)"
    internal: true
    nec:
      address: 0xEF00
      command: 0xF20D
    on_press:
      - light.turn_on:
          warm_white : 1.0
          cold_white: 1.0
  # Button 19: CW (Cool White)
    name: "CW (Cool White)"
    internal: true
    nec:
      address: 0xEF00
      command: 0xF10E
    on_press:
      - light.turn_on:
          warm_white : 0.0
          cold_white: 1.0
  # Button 20: Colortemperature up
    internal: true
    nec:
      address: 0xEF00
      command: 0xF00F
    on_press:
      - light.turn_on:
          color_temperature: !lambda |-
            float current_temp = id(cw_ww).current_values.get_color_temperature();
            // Verhoog (koelere lichtkleur) door mireds met 10% te verlagen
            float new_temp = current_temp * 1.1;
            // Bewaak de grenzen
            if(new_temp < 153) new_temp = 153;   // ~6500K
            if(new_temp > 370) new_temp = 370;   // ~2700K
            return new_temp;
  # Button 21: Effect Speed+
    internal: true
    nec:
      address: 0xEF00
      command: 0xEF10
    on_press:
      - lambda: |-
          id(active_effect) += 1;
          if (id(active_effect) > 7) id(active_effect) = 1;  // Restart at the first effect
          auto call = id(rgb_partition).turn_on();
          switch (id(active_effect)) {
            case 1:
              call.set_effect("Rainbow");
              break;
            case 2:
              call.set_effect("Color Wipe");
              break;
            case 3:
              call.set_effect("Scan");
              break;
            case 4:
              call.set_effect("Twinkle");
              break;
            case 5:
              call.set_effect("Random Twinkle");
              break;
            case 6:
              call.set_effect("Fireworks");
              break;
            case 7:
              call.set_effect("Sound Rainbow Effect");
              break;
          call.perform();
  # Button 22: Mode Stop Effect
    internal: true
    nec:
      address: 0xEF00
      command: 0xEE11
    on_press:
      - lambda: |-
          id(active_effect) = 0;  // Set active effect to none
          call.set_effect("None");  // Stop effects
          call.perform();
  # Button 23: Effect Speed-
    internal: true
    nec:
      address: 0xEF00
      command: 0xED12
    on_press:
      - lambda: |-
          id(active_effect) -= 1;
          if (id(active_effect) < 1) id(active_effect) = 7;  // Go to the last effect
            case 1:
              break;
            case 2:
              break;
            case 3:
              break;
            case 4:
              break;
            case 5:
              break;
            case 6:
              break;
            case 7:
              break;
          call.perform();
  # Button 24: Colortemperature Down
    internal: true
    nec:
      address: 0xEF00
      command: 0xEC13
    on_press:
      - light.turn_on:
            float new_temp = current_temp * 0.9;
            return new_temp;
  # Button 25: sound effect
    internal: true
    nec:
      address: 0xEF00
      command: 0xEB14
    on_press:
      then:
        - light.turn_on:
            effect: "Sound Rainbow Effect"
wel done! I noticed jerky motion when changing color, something i didnt have with the simple config. The log is flooding with mic level. Maybe thats related, that the chip cannot keep up?
button 3 and 4 are reversed in your config. Addresses are correct it seems so its just a typo
when the logger level is set to info, you no longer see the mic level: logger:
level: INFO . (also changed previous post). I will take a look into the color transition and swap button 3 and 4
i which i could contribute more but i can only understand the syntax and remove/adjust a little etc.
There is a weird interaction with the speed+ Mode and Speed- on the remote. maybe a mixup there as well not sure Ill have a look. The rest of the buttons seem to work ok!
I removed the mic and the rainbow sound effect and added the web_portal, see if it sticks here. Maybe the chip chokes on the mic input spam?
Also: Why is the powertoggle needed? CCW and RBG can do on/off right?
I made it so that when there is no light active the 24V to the strip is also toggled. I have not looked at power consumption, but it seemed logical to me. Also White and RGB cannot be active at the same time, this is because i cannot think of a scenario where this is needed. But feel free to adjust to your needs :slight_smile:
By adding default_transition_length: 0.5s to the rgb light config the transition looks to be more fluid. Maybe a lack of buffer to do the default 1s transitions. i have also changed this in the config above
edit: changing the logger level seems to change the webserver behavior. (webserver added to config)
