Using Lydsto R1 Robot Vacuum Cleaner in Home Assistant
I have an R1 robot vacuum cleaner. I want to use it with the Mi Home app but I can’t get it into app mode. What should I do?
Hi, welcome to the forum!
Are you using HA already?
From R1 robot vacuum cleaner home assistant at DuckDuckGo
Xiaomi Lydsto R1
Don’t know if this is the same (rebranded) one but apparently there is no core integration for that model → Integrations - Home Assistant
Tip for adding (getting) devices to (for use with) HA: check the forum, integrations and do some basic searching to avoid disappointments.
HTH
As a result of my searches, vacuum cleaners in other countries can connect to the Mi Home application as well as the Lydsto application. They connect through it. However, I cannot connect it to the Mi Home application in any way.
