Using Microsoft Copilot to Create zwave JS automation YAML - Seasonal Lighting
One of the challenges as a new user to zwave JS was to create the automation YAML. I turned Microsoft Co-Pilot to help. Living north of the 50 parallel, I needed a script that would recognize the summer and winter seasons and turn my outside lights on and off depending on the different sunset and sunrise times. The script below does not work in December because I am using my soffit Christmas lights instead of my regular soffit lights. Below are the steps I did and the script Co-Pilot created. If you want to use this code copy it into Co-Pilot and ask to check that is ready to use as an automation YAML.
Steps
  1. Manually back up home assistant
  2. Open Microsoft Co-Pilot
  3. Type in zwave device commands in English. E.g.
    a. For switch.front_porch_in_wall_paddle_switch_300s_2 create a automation YAML with comments, log to logbook so the entity is on between Sept 21 and March 20 for Tuesday, Wednesday and Thursday from 0615 to Sunrise plus 00:35:00 and on between Sept 21 and November 30 and January 1 and March 20 from sunset -00:45:00 and 2000 hours. Check status of light if on leave on.
  4. Copilot YAML output
alias: Front Porch Seasonal Lighting Control
description: >
Controls the front porch paddle switch with seasonal morning and evening logic.
• Sept 21–Mar 20 (Tue–Thu): ON at 06:15, OFF at sunrise + 35 minutes
• Sept 21–Nov 30 & Jan 1–Mar 20: ON at sunset -45 minutes, OFF at 20:00
• Logs all actions to the logbook
mode: parallel
TRIGGERS
Morning ON (06:15)
  • platform: time
    at: “06:15:00”
Morning OFF (sunrise + 35 minutes)
  • platform: sun
    event: sunrise
    offset: “00:35:00”
Evening ON (sunset -45 minutes)
  • platform: sun
    event: sunset
    offset: “-00:45:00”
Evening OFF (20:00)
  • platform: time
    at: “20:00:00”
ACTION LOGIC
  • choose:
    1) MORNING LOGIC — Sept 21 → Mar 20 (Tue/Wed/Thu)
    • conditions:
      Date range: Sept 21 → Mar 20
      • condition: template
        value_template: >
        {% set m = now().month %}
        {% set d = now().day %}
        {{ (m > 9) or (m == 9 and d >= 21) or (m < 3) or (m == 3 and d <= 20) }}
      Only Tue/Wed/Thu
      • condition: time
        weekday: [tue, wed, thu]
      Trigger must be morning ON
      • condition: trigger
      sequence:
      Turn ON (safe even if already ON)
      • service: switch.turn_on
        entity_id: switch.front_porch_in_wall_paddle_switch_300s_2
      Log action
      • service: logbook.log
        name: Front Porch Lighting
        message: “Morning ON (06:15, Tue–Thu, Sept 21–Mar 20)”
    • conditions:
      Same date range
        value_template: >
      Tue/Wed/Thu only
      • condition: time
      Trigger must be morning OFF
      sequence:
      Turn OFF at sunrise + 35
      • service: switch.turn_off
      Log action
        message: “Morning OFF (sunrise + 35 min, Tue–Thu)”
    2) EVENING LOGIC — Sept 21 → Nov 30 AND Jan 1 → Mar 20
    • conditions:
      Date range: Sept 21 → Nov 30 OR Jan 1 → Mar 20
        value_template: >
        {{ (m == 9 and d >= 21) or (m > 9 and m < 12) or
        (m == 11 and d <= 30) or
        (m == 1) or (m == 2) or (m == 3 and d <= 20) }}
      Trigger must be evening ON
      sequence:
      Log action
        message: “Evening ON (sunset -45, seasonal)”
    • conditions:
      Same seasonal date range
        value_template: >
      Trigger must be evening OFF
      sequence:
      Turn OFF at 20:00
      Log action
        message: “Evening OFF (20:00, seasonal)”
Would you be so kind as to adjusting the format of your code so that we can read it properly & check the YAML spacing, etc. Editing your original is the preferred way.
You can use the </> button like this… How to format your code in forum posts
OR… Here is an example of how to fix formatting from the site FAQ Page.
How to help us help you - or How to ask a good question.
