I have been struggling now for over a week to set up my Raspberry Pi3 installation of home-assistant to work with both local mqtt devices and password protected external Owntracks mqtt input. I have totally failed and am just on my 4th completely new installation from scratch as I seem to be able to break things faster than I can reprogram them! Can anyone offer any advice please, or point me in the direction of instructions I can understand with my ancient newbie mind? I tried doing the Docker install as suggested on the examples page of the website but couldn’t get the part where it should set up a password to work as it kept telling me that the mosquito-ext container wasn’t running. All I succeeded in doing was breaking the local mqtt switches I have connected. I have trawled web pages, videos and forums till my eyes bled but I haven’t found anything which gives a complete workable solution - some get close but then dissolve into geek-speak which I can’t understand and refer to things which I can’t find (‘bus’ for example…). Please help before the men in white coats come to take me away…
You haven’t really provided enough detail to explain why it’s not working, but what you want to do is very possible.
Configure and install mqtt and test it outside of hass (I use mqttlens - a chrome app). Ensure it requires a password.
Then configure HASS to use it. again use mqttlens to ensure you can see the messages hitting the queue.
Finally expose mqtt to the internet and configure owntracks. I highly recommend using lets encrypt (best) or encrypt the payload for owntracks.
If you list some errors, or the bits that cause you issues it would help a lot!
Thank you Rossdargan, If it makes things clearer, here are my configuration, sensors and customization files…
Configure.yaml…
homeassistant:
Name of the location where Home Assistant is running
Location required to calculate the time the sun rises and sets
latitude: ***********
longitude: **********
Impacts weather/sunrise data (altitude above sea level in meters)
elevation: 243
metric for Metric, imperial for Imperial
unit_system: metric
Pick yours from here: http://en.wikipedia.org/wiki/List_of_tz_database_time_zones
time_zone: Europe/London
customize: !include customize.yaml
Show links to resources in log and frontend
introduction:
Enables the frontend
frontend:
Enables configuration UI
config:
http:
Uncomment this to add a password (recommended!)
api_password: ******
Uncomment this if you are using SSL or running in Docker etc
base_url: *****.duckdns.org:8123
Checks for available updates
updater:
Discover some devices automatically
discovery:
ignore:
- media_player.unnamed_device
Allows you to issue voice commands from the frontend in enabled browsers
conversation:
Enables support for tracking state changes over time.
history:
Phone Tracking
device_tracker:
- platform: owntracks
max_gps_accuracy: 200
mqtt:
broker: 192.168.0.25
port: 1883
client_id: home-assistant-1
username: home
password: ********
light:
platform: hue
host: 192.168.0.3 -
platform: mqtt_json
state_topic: “ian/strip”
command_topic: “ian/strip/set”
effect: true
effect_list:- bpm
- candy cane
- confetti
- cyclon rainbow
- dots
- fire
- glitter
- juggle
- lightning
- noise
- police all
- police one
- rainbow
- rainbow with glitter
- ripple
- sinelon
- solid
- twinkle
brightness: true
flash: true
rgb: true
optimistic: false
qos: 0
input_slider:
strip_animation_speed:
name: Strip Animation Speed
initial: 150
min: 1
max: 150
step: 10
automation:
- alias: “Strip Animation Speed”
initial_state: True
hide_entity: False
trigger:- platform: state
entity_id: input_slider.strip_animation_speed
action: - service: mqtt.publish
data_template:
payload: ‘{“transition”:{{ trigger.to_state.state | int }}}’
- platform: state
media_player:
- platform: panasonic_viera
host: 192.168.0.6
View all events in a logbook
logbook:
Track the sun
sun:
Sensors and weather
sensor: !include sensors.yaml
wemo:
mysensors:
gateways:
- device: mqtt
persistence_file: ‘/home/homeassistant/.homeassistant/sonoff_1.json’
topic_in_prefix: ‘sonoff_1-out’
topic_out_prefix: ‘sonoff_1-in’
optimistic: false
persistence: true
retain: true
version: 2.0
switch:
- platform: mqtt
name: “Wemos D1_1 MQTT”
command_topic: “home/D1_1/gpio/5/set”
state_topic: “home/D1_1/D1_1_relay/state”
payload_on: “1”
payload_off: “0”
qos: 0
retain: true
optimistic: false
panel_iframe:
router:
title: ‘Router’
url: ‘http://192.168.0.1’
Text to speech
tts:
platform: google
group: !include groups.yaml
Sensors.yaml…
SENSORS
platform: systemmonitor
resources:- type: disk_use_percent
arg: / - type: memory_free
- type: processor_use
- type: last_boot
platform: yr
monitored_conditions:- temperature
- symbol
- precipitation
- windSpeed
- pressure
- windDirection
- humidity
- fog
- cloudiness
- lowClouds
- dewpointTemperature
platform: darksky
api_key: 4f221d6e6105370f68e4187d5d5e606d
monitored_conditions:- summary
- icon
- temperature
- apparent_temperature
- humidity
- precip_probability
- wind_speed
- wind_bearing
- dew_point
- nearest_storm_distance
platform: moon
platform: mqtt
name: “Lounge Uplighter”
state_topic: “home/sonoff_1/lounge_uplighter/1/power”
and customize.yaml…
Weather
Sensors
sensor.dark_sky_summary:
friendly_name: Conditions
sensor.dark_sky_temperature:
friendly_name: Temperature
sensor.dark_sky_apparent_temperature:
friendly_name: Feels Like
sensor.dark_sky_humidity:
friendly_name: Humidity
sensor.dark_sky_precip:
friendly_name: Rainfall
sensor.dark_sky_precip_probability:
friendly_name: Percent Chance of Rain
sensor.dark_sky_wind_speed:
friendly_name: Wind Speed
sensor.dark_sky_wind_bearing:
friendly_name: Wind bearing
sensor.dark_sky_dewpoint:
friendly_name: Dewpoint
sensor.dark_sky_nearest_storm_distance:
friendly_name: Distance to nearest storm
Hide Duplicate Hue Lights
light.back_bedroom_2:
hidden: true
light.declans_bedroom_2:
hidden: true
light.front_bedroom_2:
hidden: true
light.hall_2:
hidden: true
light.t_v_light_2:
hidden: true
In trying to set up Owntracks, I followed the instructions for installing Docker in the examples page on Home-assistant.io and succeeded in setting up the ‘mosquitto-int’ and ‘mosquitto-ext’ containers as it says, however, when I came to the next part which should open me a command prompt to set a password for ‘mosquitto-ext’ I kept getting error messages that the container was not running and the command exited. ‘Docker ps -a’ showed both containers but said they had stopped running and ‘docker ps’ didn’t show them at all. I could not find a way to get past this despite trying every possible looking permutation of commands from the docker help… What it did do though, was to stop communicating with the ‘light:’ in configure.yaml which was set up using Bruh’s instructions and was previously working. I wasn’t able to get communication with the ‘switch:’ item as it also said that it was unable to reach the address and, when I tried to turn these items on from the front panel both of the switch icons turned on and then off 1 second later.
The configure file gives a minor error because I put an entry under ‘discover:’ to hide an ‘unnamed_device’ which was actually my TV that it automatically discovered - the script complains that the device name isn’t on its approved list but it nevertheless does hide it… Sorry this is so long.
Sorry, the formatting didn’t work right but I hope you can make sense of it…
Yeah that formatting doesn’t help -it might be worth just cutting it down to the owntracks and mqtt bit anyway.
Try typing “docker logs mosquitto-ext”
