Using MQTT, out of three sensors only one is detected by HA?
Hi!
recently picked up an old HA/esphome project to finish the HW, but run into an issue with only one out of three sensors showing up in HA.
They all appear normally in MQTT.
They show up in homeassistant/sensors and under name/sensor/temperature and name/sensor/humidity
In HA only battery_voltage is showing up as an entity.
Here’s my code:
substitutions:
  friendly_name: ESP32 PM d4
  ip: x.x.x.x
  sensor_name: dht_sensor
  sleep_time: 14s
  update_sensor_interval: 10s
esphome:
  friendly_name: ${friendly_name}
  min_version: 2024.6.0
  name_add_mac_suffix: false
  project:
    version: dev
  on_boot:
    then:
      - delay: 1s
esp32:
  board: esp32dev
  framework:
    type: arduino
globals:
  - id: ota_mode
    type: bool
    initial_value: 'false'
# Enable logging
logger:
mqtt:
  broker: !secret mqtt_broker_ip
  username: !secret mqtt_sensors_user
  password: !secret mqtt_sensors_password
  birth_message:
  will_message:
  discovery: true
  discovery_retain: True
  on_message:
    - topic: esphome/ota_mode # Deep sleep stop
      payload: 'ON'
      then:
        - deep_sleep.prevent: deep_sleep_control
        - globals.set:
            value: 'true'
        - logger.log:
            format: "OTA mode enabled - Deep sleep prevented"
    - topic: esphome/ota_mode # Deep sleep start
      payload: 'OFF'
      then:
        - globals.set:
            value: 'false'
        - logger.log:
            format: "OTA mode disabled - Entering deep sleep"
        - deep_sleep.allow: deep_sleep_control
    - topic: $name/sensor/temperature/state
      then:
        - if:
            condition:
              lambda: 'return !id(ota_mode);'
            then:
              - logger.log:
                  format: "Shoud go to sleep"
              - deep_sleep.enter: deep_sleep_control
  - id: battery_voltage
    platform: adc
    pin: GPIO35
    accuracy_decimals: 3
    update_interval: $update_sensor_interval
    attenuation: auto
    filters:
      - multiply: 1.75
  - id: dht_sensor
    platform: dht
    model: DHT22
    pin: GPIO33
    temperature:
    humidity:
wifi:
  power_save_mode: LIGHT #There are other options. Just checking if this helps with self heating.
  fast_connect: true # Skip wifi scan to save time.
  ssid: !secret wifi_ssid
  manual_ip:
    static_ip: $ip
    gateway: x.x.x.x
    subnet: 255.255.255.0
  # If changing the name or the IP address of the device, this provides the old address so that ESPHome knows which device to overwrite.
  use_address: $ip
deep_sleep:
  sleep_duration: $sleep_time
  #run_duration: $run_time
