hongtat
(H)
November 9, 2018, 3:00am
1
In MQTT components, I can use MQTT Statesteam to receive state changes.
How do I control non-MQTT devices using MQTT? Or I have to use the REST / WebSocket API to control them?
Is this possible?
$ mosquitto_pub -t "homeassistant/switch/bedroom_light" -m ON
gpbenton
(Graham)
November 9, 2018, 7:01am
2
This is an introduction to MQTT, which I think is really what you need.
https://www.hivemq.com/blog/how-to-get-started-with-mqtt
nickrout
(Nick Rout)
November 9, 2018, 7:09am
3
The answer is in a careful reading of your question.
hongtat
(H)
November 9, 2018, 8:16am
4
Let me try to rephrase my question -
I have a TP-Link Switch named “fan_switch”, and I have configured MQTT statestream to publish state changes to MQTT broker, so if “fan_switch” is turned ON, it will publish on to "homeassistant/switch/fan_switch/state"
Is there a way for HASS to subscribe to "homeassistant/switch/fan_switch/command"
so that I can publish “off” to that topic to have HASS turn OFF the “fan_switch”?
mqtt_statestream:
base_topic: homeassistant
include:
domains:
- switch
nickrout
(Nick Rout)
November 9, 2018, 8:55am
5
How does your TP-Link communicate with MQTT?
hongtat
(H)
November 9, 2018, 9:17am
6
TP-link is not using MQTT, it is using - https://www.home-assistant.io/components/switch.tplink/
I’m using TP-Link as an example, it can be any of the switches under the “switches” component.
I can use REST API /api/services/switch/turn_off
+ entity_id to OFF the switch. Is there an equivalent for using MQTT topics to turn the switch on/off ?
nickrout
(Nick Rout)
November 9, 2018, 9:19am
7
Why would you need that? HA can control it without putting MQTT between them.
hongtat
(H)
November 9, 2018, 9:31am
8
Yea, I know. I’m building a bridge to sync all devices between HA and another smart home hub.
gpbenton
(Graham)
November 9, 2018, 9:32am
9
To do this you would write an automation that triggers off the MQTT message and sets the switch state accordingly in the action .
hongtat
(H)
November 9, 2018, 9:44am
10
But that would require me to set a MQTT trigger for each of the HA devices…
gpbenton
(Graham)
November 9, 2018, 9:58am
11
You may be able to use templates to reduce that number, but I don’t know too much about that.
Personally, I use appdaemon so I write all automations in Python.
hongtat
(H)
November 9, 2018, 4:41pm
12
Thanks for pointing me in the right direction!
- alias: Control switches via MQTT
platform: mqtt
topic: +/switch/+/cmd
- service_template: >
homeassistant.turn_{{trigger.payload}}
data_template:
entity_id: >-
{{ trigger.topic.split('/')[-3] }}.{{ trigger.topic.split('/')[-2] }}
