As I posted many times in the past, my Z-wave struggle mightily due to the very large home and building materials. Most edge devices depend on 3 or 4 hops, and are just unreliable, especially battery-powered devices.
I experimented with ser2net and a Raspberry Pi 3B+ on Wifi, to move my ZST39 stick to a more central location. This helped somewhat, but did not fully resolve the reliability problem.
I believe I can only resolve it with multiple Z-Wave sticks simultaneously, on separate networks.
I believe I could setup my ZST10 with Z-Wave JS, and leave my ZST39 on Z-Wave JS UI, as I currently do. And have either one be remote with ser2net.
However, I’m planning on adding perhaps 50-60 Z-wave nodes to the existing 70, if I can fix the reliability and coverage issue. Most of the new devices would be 800 series with SmartStart support.
As far as I can tell, you can only use SmartStart in Z-Wave JS UI, but not in standalone Z-Wave JS.
And if I understand correctly, Z-Wave JS UI currently only supports only a single Z-Wave stick.
Are there any plans to add support for multiple sticks in Z-Wave JS UI, so I could use SmartStart with both ?
The other alternative would be for me to give up on Z-Wave altogether, and replace the existing 70 nodes.
I have Yolink too, and it has been much more reliable than both Z-Wave and Z-Wave LR in my home.
The main downside with Yolink has been the app & cloud dependency, for both initial setup and operation.
I received a Yolink local hub today, to replace my existing one. I have not set it up yet. My understanding is that it still requires a cloud account and app for the initial device setup, but afterwards, it should function with HA in local mode. I will certainly test that by blocking the local Yolink hub from Internet in pfSense. But it still won’t be as good as Z-Wave, which has no app or cloud dependency for setup. The app & cloud requirement for setup are still a built-in time bomb, same as for most IOT devices, like the Wemo announcement today.
Yolink also has a much smaller subset of devices than Z-Wave, as there is only one manufacturer for them. But their motion sensor works great in my metal, and on my kitchen counter that don’t have light switches on every side. Whereas the Z-Wave battery devices I have tried just don’t work at all in the mailbox, or reliably on the counter.
The Yolink door sensors range is a bit too short. I have not yet experimented with alternate magnets yet. Perhaps it’s possible to improve.
The batteries for the Yolink temperature sensors and door sensors also don’t last long in enough the fridge & freezers. If the door sensors had longer range, I could put them on the outside rather than inside. Not sure if anyone makes battery powered temperature sensors that will last in freezers, and with which battery chemistry. The Yolink take AAAs, which gives a choice. Alkalines basically don’t work in freezers. Eneloops work somewhat, for a few weeks or months. But not years.
