Using Mushroom Light Card with a Template in Auto-Entities
So I’m trying to utilize a template to expand a preset group (Manual Lights) within an auto-entities card such that it displays only the lights within that group that are currently on using a mushroom light card.
Based on testing:
  • the first auto-entities card returns every light in the house that is on and uses the mushroom card
  • the second auto-entities card only returns lights in the Manual Lights group that are on but uses the glance card
  • the third auto-entities card is an attempt to combine the first two, however it displays nothing.
Practically speaking, the goal is to combine the first and second auto-entities cards into a single stack such that the vertical stack will have the popup bubble card listed first and a singular auto-entities card second that, using a mushroom lights card, will display only the lights in the Manual Lights group that are currently turned on. (Since it’s a popup bubble card, that one won’t actually be visible outside of the code, but you get the idea)
Anybody see where I’m going wrong? I feel like its something simple but am just not making the connection.
type: vertical-stack
cards:
  - type: custom:bubble-card
    card_type: pop-up
    hash: '#lights test'
    show_header: false
  - type: custom:auto-entities
    card:
      type: grid
      columns: 1
      square: false
    card_param: cards
    filter:
      include:
        - domain: light
          state: 'on'
          options:
            type: custom:mushroom-light-card
      exclude: []
    show_empty: true
    card:
      type: glance
    filter:
      template: |
        {% for light in
        expand ('light.manual_lights') %}
         {% if light.state == "on" %}
          {{ light.entity_id}},
         {% endif %}
        {% endfor %}
    card:
      type: grid
      columns: 1
      square: false
    card_param: cards
    filter:
      template: |
        {% for light in
              'type': 'custom:mushroom-light-card'
              'entity': light.entity_id
         {% endif %}
        {% endfor %}
    show_empty: true
Hi, this is syntax for merge two methods :slight_smile:
          template: |-
            {%- for light in
            expand ('light.manual_lights') -%}
             {%- if light.state == "on" -%}
                  'type': "custom:mushroom-light-card",
                  'entity': light.entity_id,
             {%- endif -%}
            {%- endfor %}
Did some more work on this and here is the solution:
cards:
    card_type: pop-up
    hash: "#lights_test"
    show_header: false
    card:
      type: grid
      columns: 1
      square: false
    card_param: cards
    filter:
      template: >
        {% set lights = expand('light.manual_lights') | selectattr('state',
        'eq', 'on') | list %}
        [{% for light in lights %}
            "type": "custom:mushroom-light-card",
            "entity": "{{ light.entity_id }}"
          }{% if not loop.last %},{% endif %}
        {% endfor %}]
    show_empty: true
