I have just managed to setup a Telegram bot and configure my entities to trigger a notification. Very useful system. For simplicity is it possible to send a reply to my bot which then resets an entity state for me?
I have searched here in the forum and not found any help so far with that?
I will revisit the documentation and report back if I find a solution.
I’m not sure what you mean by “resets an entity state”, but if you can do it in an HA automation, it can be triggered by a telegram message.
In my own setup, I have the telegram bot send me an inline keyboard with a few buttons to click to reply with, then use event_type: telegram_callback to respond.
I believe this is the original thread that got me started with the basics:
Thanks very much @Silicon_Avatar! That should put me on the right path I think. Yes I can do that in an automation.
What I am trying to do is be able to reset a tripped process in my water treatment system.
Telegram message:
HA_alert_bot
Grey Water Run Count is Tripped
One more question for you (if I may) @Silicon_Avatar?
Is it possible to have the initial message the bot sends (in response to the trip condition) to me include the inline keyboard? Or do I need to communicate back to the bot first?
Can you perhaps detail how you set that up please?
Cheers again!
Before I had access via VPN or ZeroTier I used Telegram extensively to communicate with my HA (without having to open a port).
I have a generic call back automation to ‘end a conversation’ and remove the keyboard and I am pretty sure it always worked. Which is surprising as it looks identical in principle to what you are doing.
I think it might be because my actions ( script.alarm_disarm ) also includes a Telegram notification and I’m confusing the bot. I’m not really fussed. I commented it out. Now I get a reply from the script and the keyboard eventually disappears into the chat history spaz.
