When adding multiple similar entities a way to include a template file, load it with dynamic variables and the result is parsed as configuration. Something like this in configuration.yaml
!include_template: templates/shelly_1pm.j2
base_topic: shellies
ids:
- aabbccddee
- ddeeffa339a
- 3344bbccaa
And the template could hold all the entities that is required for this device
{% for id in data.ids %}
- sensor:
platform: mqtt
name: "Shelly {{ id }} power usage"
state_topic: {{ data.base_topic }}/{{ id }}/meter/power
- switch:
name: "Shelly {{ id }} relay"
platform: mqtt
command_topic: { data.base_topic }}/{{ id }}/relay/0/command
state_topic: { data.base_topic }}/{{ id }}/relay/0
payload_on: "on"
payload_off: "off"
{% endfor %}
A library of templates could be built up for common devices. I’m sure that there could be other uses for templates around the configuration
