I have a Nedis zigbee remote control and it is added in Home Assistant as TS0215A by _TZ3000_fsiepnrh.
It created 1 entity for alarm control panel (alarm_control_panel.zigbee_remote_ias_ace), one sensor for zone (binary_sensor.zigbee_remote_ias_zone) and one entity for power (sensor.zigbee_remote_power).
The remote has 4 buttons: O, I, A, B.
If I press O - alarm is triggered.
If I press I - I see a ZHA event with “arm_mode_description”: “Arm_All_Zones”
If I press A - I see a zha_event with “arm_mode_description”: “Arm_Day_Home_Only”,
If I press B - I see a zha_event with “arm_mode_description”: “Disarm”
But I do not want to use the RC as an alarm panel. What I want is:
O - open by garage
I - open one door
A - open main gate
B - open secondary gate
So basically I want to trigger one automation on every button press.
But being recongnized as an alarm control panel it doesn’t behave as a button. O triggers the alarm and if I press it again, it won’t send any event anymore.
Is there a possibility to force ZHA to not anymore create alarm_control_panel entity but a button?
I tried something like:
zha:
device_config:
bc:33:ac:ff:fe:61:xx:xx:
type: "button"
but nothing changed.
Any advice on how can I force HA or ZHA to create a button or something else than a alarm_control_panel entity?
Zigbee info:
IEEE: bc:33:ac:ff:fe:61:xx:xx
Nwk: 0xe18e
Device Type: EndDevice
LQI: 248
RSSI: -38
Last Seen: 2022-10-31T13:58:48
Power Source: Battery or Unknown
