I have a problem with accessing network drives. I have samba setup and working when accessing my config file from my windows computer. However I would like to go the other way around. I want my raspberry pi/home assistant to access my NAS and use files from a folder on the NAS.
Well I’m the admin so I can choose whatever permissions I like. Basically what I’m asking is HOW I can link to a folder on a network drive. No matter what I write as a link it “can’t find it” so I’m thinking about if its the syntax I’m using that’s wrong.
Reading from the PI sd-card itself works just fine, no matter what I put on it, it’s just that I can’t seen to read from a network drive
I have only samba share on my network and no dedicated NAS but I don’t think you can directly access network share file/folder in HA, at least not samba share in HA.
Have not used folder watch yet, if it’s anything like inotifywait, it probably would not work on network share either.
I used to mount my snapshot share folder in HA machine and then process/copy files using a bash script into a /local folder for HA to use. (switched to camera.snapshot now)
It’s quite clumsy, but your jpg is on synology NAS, ftp to HA first may be a possible?
Perhaps they mounted the shared volume on the HA node or (not checked this) depending how HA accesses files and folders some methods allow shares to be specified like smb://server/share/file or cifs://server/share/file
When I did this, we did not have folder watcher, etc, components
My old set up was:
ipcam saves regular snapshots, i.e. every 5 seconds
HA machine had log in script that mounted the share drive from ipcam to a /media folder
an automation triggered by motion sensor to copy the latest jpg file from the mounted /media folder to a folder under /local/www for archive and use with notify component.
The scripts used were nothing special, just mounting samba share, and copying file from /media to /local/www.
Like I said, it was quite clumsy but that’s before camera.snapshot and watch(er) components.
You may want to follow up with @wmaker on the use case, that’s still better solution if works.
I should clarify one of my statements…the NFS mount was from the viewpoint of the camera;
In other words it was the camera that was mounting a file system from a directory on my Ubuntu system
the same Ubuntu system that was running HA.
Excuse me guys but I still doesnt understand. Can we access network folders from our home assistant installation(pi running rassbian) or not? It doesn’t matter what components I need to use, or scripts for that matter, I just need it to work somehow.
My experience was I could not access network folders directly with HA, mounted or not.
But a command line or bash script run by HA can access the mounted network file/folder.
Hi, have the same problem, I can map network drive using terminal but can’t view it in Configurator or find it in installed Plex server. Is there any direct instructions to check permissions?
thanks
