Using NGROK for google assistant help!
hello guys
I am using ngrok addon for my hassos for remote access of home assistant and this is because my ISP does not allow for port forwarding and I am also in NAT.
Ngrok addon works great with just minimal adjustments in the config and you are good to go.
Now the issue is “I want my google assistant to work with HA” so, I followed all the steps for google assistant integration manually ie without Nabu casa.
All the steps are done. In my google home app, I get the “[test] my test app” which means everything is ok and after tapping it I get the home assistant login as well, but after all these, it shows me “Something went wrong. Try again” can anyone help me with this?
Hi! Did you manage to get this working?
@leonardomrc no this solution is not working I shift to nodered for google home integration
