Hi folks, I have the following automation in place for closing respective garage doors when either household member leaves home:
description: Close respective garage door when Amy or Mark leave home
- entity_id: person.mark_fulton
platform: state
to: not_home
- entity_id: person.amy_fulton
platform: state
to: not_home
condition: []
- choose:
- conditions:
- condition: and
conditions:
- condition: trigger
- condition: state
entity_id: cover.garage_door_mark
state: open
- condition: template
value_template: >-
{{ as_timestamp(now()) -
as_timestamp(states.sensor.uptime.last_changed) | int > 300 }}
sequence:
- service: notify.signal_warning
title: Mark left home!
message: Closing Mark's garage door
- service: cover.close_cover
data: {}
- conditions:
- condition: and
conditions:
- condition: state
entity_id: cover.garage_door_amy
state: open
value_template: >-
sequence:
title: Amy left home!
message: Closing Amy's garage door
data: {}
default: []
mode: single
As you can see household members both have separate cars with respective garage door covers.
I need to solve the case for the opposite arrival based automation where we arrive back at the house, both in the same car, the correct door opens.
Other threads suggest the bluetooth state of the companion app to identify the car, but we have iOS devices and don’t have this sensor. I also do not have car sensors in the garage that can tell which car is present/not present.
The next best solution I thought of was using the outcome of the garage door entity that was closed in the car leaving automation, paired with a person group sensor state transition, something like:
If group.amyandmark sensor transition to home, open the last garage door entity closed by the ‘close garage door’ automation
But checking docs I’m not sure if/how I can accomplish this. Is there a way in a template (or otherwise) I can reference which entity was selected in the last run of a different automation?
Based on your explanation, Home Assistant has no information about two cars, only about two persons.
If Mark leaves with Amy’s car, the automation will attempt to close Mark’s garage door. It should attempt to close Amy’s garage door but it has no information about her car’s location, just Mark’s location.
If both persons return home in the same car, there’s nothing indicating they’re ‘grouped’ into one of the two cars, therefore the automation will open both of the closed doors.
If each car had its own device tracker, then Home Assistant could make correct decisions about which door to open/close including tricky situations like both Mark and Amy leaving/arriving in Mark’s car or Mark leaving/arriving in Amy’s car.
Correct on all three points. As you mention in an ideal situation we’d have device tracking on the cars.
The challenge is getting a reliable device tracker - I can’t use the companion app as we have iOS devices, so no bluetooth sensor.
So, the next best option is to use the sensors we have creatively. We are using homekit to do presense detection which has been solid.
The two scenarios you describe:
If both persons return home in the same car, there’s nothing indicating they’re ‘grouped’ into oneof the two cars, therefore the automation will open both of the closed doors.
That’s what’s happening today and I’m looking to improve. However, because the garage door close automation works correctly when both persons leave home in the same car, my thought is to setup a third action condition that triggers off group presense and opens the garage door that was the last one to close. Need to find out if this is possible/how to accomplish this.
This is an edge case I’m OK to live with - if I drive my wifes car 99% of the time we are both in it. The other 1% is if I take it for maintenance. For security I can setup a notifier based automation that alerts me when the garage door is open for longer periods of time.
You could install Bluetooth trackers in each vehicle. Use that in combination with the person entities to correctly determine which door to open for all situations.
That sounds plausible provided you create an ‘old-style’ Group entity and set its all option to true (i.e. it will report on/off only when bothperson entities are home/not_home).
Then added two new choose conditions in the action section of the open garage door automation. This is quite long winded but will hopefully accomplish what I need it to:
alias: Garage - OPEN - Door - Amy or Mark garage door when Amy or Mark arrive home
description: Open respective garage door when Amy or Mark arrive home
platform: state
to: home
platform: state
to: home
- entity_id:
- group.amyandmark
platform: state
to: home
condition: []
- choose:
- conditions:
- condition: and
conditions:
- condition: state
state: closed
value_template: '{{ as_timestamp(now()) - as_timestamp(states.sensor.uptime.last_changed)
| int > 300 }}'
sequence:
title: Mark arrived home!
message: Welcome home Mark! Opening Mark's garage door
- service: cover.open_cover
data: {}
- conditions:
- condition: and
conditions:
- condition: state
state: closed
| int > 300 }}'
sequence:
title: Amy arrived home!
message: Welcome home Amy! Opening Amy's garage door
data: {}
- conditions:
- condition: and
conditions:
- condition: state
state: closed
- condition: state
entity_id: input_text.garage_door_last_closed
state: amy
| int > 300 }}'
sequence:
title: Amy and Mark arrived home!
message: Welcome home Amy & Mark! Opening Amy's garage door
data: {}
- conditions:
- condition: and
conditions:
- condition: state
state: closed
- condition: state
state: mark
| int > 300 }}'
sequence:
message: Welcome home Amy & Mark! Opening Mark's garage door
data: {}
default: []
mode: single
When you are both in the same car and arriving in the home zone, let’s say Amy’s phone is the first to report it has entered the home zone (because there’s no way both phones can report their arrival in the home zone at the exact same moment in time). Therefore it will cause the automation to trigger via its second State Trigger and open Amy’s garage door. That might not be the correct door if both departed in Mark’s car.
Then when Mark’s phone enters the home zone (perhaps seconds or milliseconds later), it’s a tossup between which of the two remaining State Triggers gets triggered first, the one just for Mark’s arrival home or the one monitoring the arrival of the group.
If Amy’s phone is the first to report a home state, Amy’s presence switching to home should also flip the groups sensor group.amyandmark to home at the same time, meaning its a toss up between the group state and Amy arriving at this point… hmm.
Is there some sort of evaluation priority that I could set here and set the trigger priority for the group condition higher?
Don’t you think, that this can only holdup as a workaround? This all would be easily solveable by two BT beacons and an ESP32. I could even imagine using a Shelly UNI, connected to the car battery and work with signal strength of the WIFI. But working with a “person” trigger for a car?
Don’t misunderstand me, I find this topic interesting, that’s why I’m following from the beginning, but I get the feeling, investing some $20 or $30 bucks might not be a bad idea, don’t you think?
Not if the group sensor is configured to report on only when both Mark and Amy are home. If it’s not configured like that then it will report on when either Mark or Amy is home which defeats its intended purpose (group.amyandmark).
It’s first come, first served; there’s no priority.
Like I suggested in my first post, equip the two cars with device trackers. Besides simplifying the automation, and properly handling edge cases, it’s more secure to detect the cars when they’re on the driveway and not when your phones have just entered the periphery of your home zone (which I assume is larger than the bounds of your property).
Thank you - yes I see, ESP32 and a couple of USB powered BT beacons for the cards would be pretty inexpensive and more secure. But nevertheless glad to have exhausted options using phone device trackers. Thanks again for the great input!
