I need help using Packages.
I see an error asking for a “platform key”
The error is “Invalid config for ‘binary_sensor’ at packages/driveway/functionality1.yaml, line 3: required key ‘platform’ not provided”
I need help to understand what a “platform key” is and how to use it in a Package.
It would be really helpful if you could post the YAML for functionality1.yaml. There’s a reasonable possibility that you have an indent error, missing closing quote or bracket, or just have the YAML wrong. But nobody can help you without seeing the actual YAML.
Thanks for such a quick response.
I have been working with HA for a few months and decided to organize my stuff using Packages.
I am stuck resolving a bug that is asking for a Key for Platform.
Here is the YAML for my config and the package…
filename: /homeassistant/configuration.yaml
# Loads default set of integrations. Do not remove.
default_config:
homeassistant:
packages: !include_dir_merge_named packages/
# Load frontend themes from the themes folder
frontend:
themes: !include_dir_merge_named themes
template: !include_dir_merge_named templates
scene: !include scenes.yaml
script: !include_dir_merge_named scripts
###sensor: !include_dir_merge_named sensors
###binarysenesor: !include_dir_merge_named binarysensors
switch:
switches:
ewelink_virtual_switch:
turn_on:
service: switch.turn_on
turn_off:
service: switch.turn_off
filename: /homeassistant/packages/driveway/functionality1.yaml
driveway_functionality1:
binary_sensor:
- name: Driveway_07_B
state: "{{is_state_attr('sensor.driveway_07_wifi_connect_count', 'value', 1) }}"
- name: Driveway_DoorStatus
state: >
{% set ms1 = states('binary_sensor.driveway_controller_switch4') %}
{% set ms2 = states('binary_sensor.driveway_controller_switch3') %}
{% set status = ms1 ~ ms2 %}
{% if status == "offon" %} Closed
{% elif status == "onoff" %} Open
{% elif status == "onon" %} Moving
{% else %} Unknown ms1: {{ ms1 }} ms2: {{ ms2 }}
{% endif %}
- name: Driveway_GateStatus
state: >
{% set ms1 = states('switch.driveway_07_ms3') %}
{% set ms2 = states('switch.driveway_07_ms2') %}
{% set status = unavailable %}
{% if status == "onoff" %} Open
{% elif status == "offon" %} Closed
{% elif status == "offoff" %} Moving
{% endif %}
Thanks in anticipation.
Please feel free to offer me suggestions about i proving my YAML.
Delete
and move everything what was under it 2 spaces to the left.
I believe you are trying to create template sensors.
If so you need to change the first section to this:
template:
- binary_sensor:
- sensor:
Thanks Francis. I tried your suggestion with this simplified YAML -
binary_sensor:
- name: driveway_07_b
This caused error:
Setup of package ‘binary_sensor’ failed: Invalid package definition ‘binary_sensor’: expected a dictionary. Package will not be initialized
I also tried suggestion from Regular but was unsuccessful and have responded separately.
Thanks Regular.
I tried your suggestion with simplified YAML:
template:
- binary_sensor:
This failed with error message:
Configuration warnings
Setup of package 'template' failed: Invalid package definition 'template': expected a dictionary. Package will not be initialized
I also tried other variations without success.
In YAML indentation is absolutely critical to get right. In the last example you provided, the binary sensor line needs to be indented two spaces. I think the lines after that will be fine (since the name line is already indented four spaces from the “root,” which will give it the two space indent from it’s parent when you are done).
Thanks everyone. I have a config that works! I asked ChatGPT for help.
I think there were two problems:
- A ‘platform’ key was required.
- the entity names needed to be lower case.
Here is the YAML that worked:
binary_sensor:
sensors:
driveway_07_b:
friendly_name: "Freddy"
value_template: "{{ on }}"
sensors:
driveway_doorstatus:
value_template: >
{% endif %}
driveway_gatestatus:
value_template: >
{% endif %}
My first experience using the Community has been very rerwarding.
Your problem was that the template:
key was missing.
You were using the modern format for template (binary) sensors.
ChatGPT now moved you back to the legacy format.
this is what you should have done:
template:
- binary_sensor:
- sensor:
state: >
{% endif %}
state: >
{% endif %}
BTW, I wouls advice to add a unique_id
to each (binary) sensor
I’m really surprised that you didn’t get an error from this:
Hi TheFes, Thanks. I tried your suggestion but the result was this error:
I used the following YAML:
template:
- binary_sensor:
- name: driveway_07_b1
Question: does the YAML need to be different for template created in a Package, rather than in a Template. In my case I am trying to create a Package!
Also; you suggested I should add a unique_id to each sensor. Can you show me syntax I need to do this?
Hi finity, Thanks. You expressed surprise that the “driveway_functionality1:” key did not cause an error. Maybe this requirement is an artifact of the fact that my YAML was for a Package rather than a Script or Template?
Feels like you’re flailing around a bit here. ChatGPT is never a good solution to writing HA code.
Exactly as per the docs:
you want:
template:
- binary_sensor:
state: "{{ is_state_attr('sensor.driveway_07_wifi_connect_count', 'value', 1) }}"
- sensor:
state:
### and so on
You don’t need the functionality1
at the end of the package name: that’s just an example.
And @finity, this is a package setup which is why we have the driveway_functionality1:
heading.
Ah, right, I forgot to include the package name in my config.
I use another include for packages where the package name is taken from the filename
Hi Troon, Thanks. You are correct, I have been flailing about!
I did read the documentation you pointed me to, several times. It did not get into my brain what the first line of the YAML is about. I have now discovered that the key there MUST be unique. If not unique then nothing happens, no error message, no nothing.
Whilst flailing I saw many error messages demanding a “platform” key but I never got to understand the issue.
Thanks for all you help.
None of my packages have package names/headers. How is the packages config different for getting the package name from the header as opposed to the file name?
I’ve never seen that syntax for packages before now.
Depends on how you set the include
in your config file.
could you give an example of the difference?
See the packages doc (link in my post above), which covers it well.
