I have two input_booleans which are driven by HomeKit based on user presence.
Is there a way to hook these up to the Persons plugin so that whether they are home or not is driven by these input_booleans?
Kind of. There is no template device tracker yetâŚbut we can kind of spoof it.
device_tracker.see will create a device tracker for us if we give a dev_id that doesnât yet exist.
So, under your person, add 2 more âdevice trackersâ. These wont exist yet. Name them the same as the input_boolean (i.e. if itâs input_boolean.homekit1, call it device_tracker.homekit1).
Then set an automation to follow the input booleans.
- alias: HomeKit Device Tracker
- platform: state
entity_id: input_boolean.homekit1
- platform: state
entity_id: input_boolean.homekit2
- service: device_tracker.see
data_template:
# Grab the object id of the trigger.
# i.e. if this was input_boolean.homekit1, trigger.to_state.object_id will be 'homekit1'
dev_id: "{{ trigger.to_state.object_id }}"
location_name: "{{ 'home' if trigger.to_state.state == 'on' else 'not_home' }}"
Awesome! Works really great! Only on reboot this automation gives the following error:
Logger: homeassistant.components.automation.homekit_device_tracker
Source: helpers/service.py:140
Integration: Automation (documentation, issues)
First occurred: 14:32:06 (2 occurrences)
Last logged: 14:32:06
Homekit naar device tracker: Error executing script. Unexpected error for call_service at pos 1: Error rendering data template: UndefinedError: 'dict object' has no attribute 'to_state'
While executing automation automation.homekit_device_tracker
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 421, in async_render
render_result = compiled.render(kwargs)
File "/usr/local/lib/python3.8/site-packages/jinja2/environment.py", line 1090, in render
self.environment.handle_exception()
File "/usr/local/lib/python3.8/site-packages/jinja2/environment.py", line 832, in handle_exception
reraise(*rewrite_traceback_stack(source=source))
File "/usr/local/lib/python3.8/site-packages/jinja2/_compat.py", line 28, in reraise
raise value.with_traceback(tb)
File "<template>", line 1, in top-level template code
File "/usr/local/lib/python3.8/site-packages/jinja2/sandbox.py", line 407, in getattr
value = getattr(obj, attribute)
jinja2.exceptions.UndefinedError: 'dict object' has no attribute 'to_state'
Got an idea whatâs the cause?
Weird. Itâs a state triggerâŚitâs got to have a to_state.
Though, maybe itâs only an attribute change. Since we didnât give a state in the trigger, an attribute will still fire an event.
Just add this condition:
condition:
- "{{ trigger.to_state is not None }}"
Also, change âdata_templateâ to just âdataâ. Both of these changes assume youâre on version 0.115 or greater.
Thanks again! The suggested condition gives me an error.
Should it be like this?
condition: "{{ trigger.to_state is not None }}"
What version of home assistant are you using?
If you arent on 0.115 or greater, do this.
condition:
condition: template
value_template: "{{ trigger.to_state is not None }}"
Iâm on the latest release 0.117.5
I know this pos its old but i make this work with this automation
alias: 'Homekit tracker '
description: ''
- platform: state
entity_id: input_boolean.alexis
- platform: state
entity_id: input_boolean.stefany
condition: []
dev_id: '{{ trigger.to_state.object_id }}'
location_name: '{{ ''home'' if trigger.to_state.state == ''on'' else ''not_home'' }}'
mode: single
