Using regex for sensors
Hi Guys,
I’m using a switch with PoE and would like to get the total value of all the PoE devices. Is it possible to do this with regex?
USW-24-PoE Port [0-9]+ PoE Power
And if so, how can I do it?
In short, yes. I’m not in front of a computer now, so I’ll just give a short description. You need to operate on the state object directly using select or selectattr (Jinja docs). There is a regex function in the HA templating docs you can use in conjunction.
