I’m trying to control my thermostat in HA from ESPHome using rotary encoder. I want to set the temp with it but for some reason it does not work. I would appreciate some help.
Thermostat is stepping values from 16 to 26 every half degree as needed but it does not pass the value to HA.
- platform: rotary_encoder
name: "Rotary Encoder Thermostat from ESPhome"
pin_a: 32
pin_b: 33
min_value: 32
max_value: 52
resolution: 2
internal: true
filters:
- lambda: return x * 0.5;
on_value:
then:
- homeassistant.service:
service: climate.set_temperature
data_template:
entity_id: climate.home_thermostat
temperature: "{{id(rotary).state}}"
nickrout
(Nick Rout)
November 2, 2020, 8:16pm
2
Logs? both HA and ESPhome
wasyl00
November 2, 2020, 11:38pm
3
Ok got it working by using the following:
pin_a: 32
pin_b: 33
min_value: 32
max_value: 52
resolution: 2
internal: true
filters:
on_value:
then:
data_template:
temperature: !lambda "return id(rotary).state;"
Now question how to sync it so when the temp value in HA changes (by adjusting in another device) this updates new starting point for rotary encoder?
nickrout
(Nick Rout)
November 3, 2020, 1:04am
4
I think start here https://esphome.io/components/sensor/homeassistant.html
Then you can use this (I think) to set the state of rotary.
Thanks! Ok managed to make it work by reading temp from HA
- platform: homeassistant
name: "Set Temperature from Home Asisstant"
entity_id: sensor.home_thermostat_temperature
internal: true
on_value:
- sensor.rotary_encoder.set_value:
value: !lambda "return id(home_set_temp).state * 2;"
err this probably should not be done this way. Weird stuff happens and number jumps up and down when I rotate encoder quickly through a few steps.
I’ve been working on a similar project, here’s my code in case it helps anyone trying to do the same.
#### ESPHOME THERMO CODE ####
#### BY STEVEN LOVEJOY ####
## NODE-MCU V3 PINOUTS ##
## D2 = DHT11 output ##
## D3 = Output_A rotary encoder ##
## D4 = Output_B rotary encoder ##
## D6 = scl 128x64 ssd1306 oled ##
## D7 = sda 128x64 ssd1306 oled ##
## 3v3 oled & DHT11 positive ##
## download font files to ##
## /config/esphome/ ##
esphome:
platform: ESP8266
board: nodemcuv2
wifi:
ssid: '**********'
password: '**************'
# Enable logging
logger:
# Enable Home Assistant API
api:
password: '*************'
ota:
password: '***************'
# TIME FROM HASSIO
time:
# LOUNGE TEMP FROM HASSIO
entity_id: sensor.lounge_temp
internal: true
# HEATING TARGET TEMP FROM HASSIO
entity_id: sensor.target_temp_2
name: "Target Temp State"
internal: true
on_value:
value: !lambda "return id(target_temp_2).state * 2;"
# ONBOARD DHT11 TEMP & HUMIDITY SENSOR
- platform: dht
pin: D2
temperature:
name: "Thermo Temperature"
humidity:
name: "Thermo Humidity"
update_interval: 60s
model: DHT11
# ONBOARD ROTARY ENCODER
pin_a: D3
pin_b: D4
min_value: 20
max_value: 70
resolution: 2
filters:
on_value:
then:
- delay: 0.2s
data_template:
entity_id: climate.lounge
temperature: !lambda "return id(thermo_encoder).state;"
# SET FONTS
font:
- file: 'slkscr.ttf'
- file: 'arial.ttf'
- file: 'BebasNeue-Regular.ttf'
# ICON SIZE 20
- file: 'materialdesignicons-webfont.ttf'
glyphs: [
"\U000F0238"
# ICON SIZE 30
glyphs: [
"\U000F0238"
# HEATING STATE BINARY FROM HASSIO
binary_sensor:
entity_id: binary_sensor.heating_state
name: "Heating State Binary"
internal: true
# HEATING STATE TEXT FROM HASSIO
text_sensor:
internal: true
# ONBOARD OLED DISPLAY
i2c:
scl: D6
sda: D7
scan: false
display:
- platform: ssd1306_i2c
model: "SSD1306 128x64"
reset_pin: D0
address: 0x3C
lambda: |-
// Print time in HH:MM format (from hassio)
it.strftime(64, 5, id(font2), TextAlign::TOP_CENTER, "%H:%M", id(times).now());
// Print font icon if heating is on
if (id(heating_state_binary).state) {
it.print(10, 0, id(icon_font_30), TextAlign::TOP_LEFT, "\U000F0238");
// Print climate target temperature (from hassio)
if (id(thermo_encoder).has_state()) {
it.printf(10, 30, id(font3), TextAlign::TOP_LEFT , "%.0f°", id(target_temp_2).state);
// Print lounge temperature (from hassio)
if (id(lounge_temperature).has_state()) {
it.printf(70, 20, id(font4), TextAlign::TOP_LEFT, "%.0f°", id(lounge_temperature).state);
Notice I added a delay to stop the same jumping around as wasyl00 experienced.
Note: in the above code I’m using the temperature from another sensor i have already setup in my lounge, I will change it to use the onboard sensor once I get it in a case and installed.
Good stuff lovejoy777 I just updated my code and it seem to be working without jumps!
Here is my desk gizmo: thermostat control/ble sensors tracker/air quality sensor display thing:D
looking good, I’ll post mine once i get it finished
the small temp is the target temp and the big temp is the actual temp, the flame icon only when the heating is on.
finally finished
Looks nice! Dont forget to make use of click button on the rotary encoder. I use mine to cycle thermostat on/off. Pretty useful.
nickrout
(Nick Rout)
January 7, 2021, 9:02pm
11
I was thinking of making the button change to a different climate entity.
i set this up too for scheduling my heating.
i will use the encoder button for my hot water.
albaboun
(alberto)
May 4, 2021, 8:37pm
15
hi lovjoy.
thank you for sharing. i am trying to read temperature setpoint for the generic thermostat at homeassistant from esphome. i follow your code but it did not work. can you help me please?.
many thanks
alberto
Sjo_Sjo
(Sjo Sjo)
June 11, 2021, 8:40pm
16
Can you post your code with the flame option?
