Recently support was added for multiple instances of AdGuard. I’ve successfully and easily added two instances with the integration. However, when trying to build an automation that uses the service call to add or remove a URL from the filter list, it doesn’t appear to me that you can define which instance you want to communicate with.
I’ve tried using target: device_id: and entity_id: but it seems the service call doesn’t support either. When I make the service call without defining a particular device or entitiy it always effects the second instance of AdGuard that I added to the integration.
Not sure if this is a missing feature of the update of the AdGuard integration, or maybe I’m doing something wrong.
