Using several Tado accounts
Dear community
Is there a way to configure several Tado accounts? Having a large home with several Tado bridges. As you know theres no way to connect more then one bridge to one account.
I would love that too!!! Anyone managed to get more than one bridge working already???
Just a plus one on this feature request. If you have more than one boiler, you have to unfortunately use multiple tado accounts.
Why is this not a standard feature for all home assistant integrations, by the way? This is at least the second time where I encountered the need of wanting to run multiple instances of an integration.
I am running three tado accounts in one HA setup now. AFAIK it is possible for a long time already.
That’s amazing if possible. How do you do it?
I am not sure because I have it working for over a year for sure. Let me try: make sure you have the most recent version and probably the second (or more) instance should be auto-discovered. If not, just add it on the integrations page and add it using the button on the bottom right. Select tado and fill in the details for the second tado bridge/account. Make sure you have a unique name for each instance. It should show up in the integrations page side by side with the other instances for the tado integration.
I just tried to do this.
I found an “Add entry” button on this page http://homeassistant.local:8123/config/integrations/integration/tado
As you can see in the screenshot, I could easily add a 2nd bridge/ tado account.
