gerd1
(Gerd Rütten)
January 22, 2024, 5:49am
1
Dear community,
I use the Sonoff ZBDongle-E with multiprotocol firmware, the Silabs multiprotocol add-on and zigbee2mqtt add-on.
Is it possible to run z2m not as an add-on, but outside of HA in its own Docker container?
If so, how should the port be declared in the z2m configuration?
If both add-ons run under HA, access from z2m to Silabs is via:
port: tcp://core-silabs-multiprotocol:9999
adapter: ezsp
But what needs to be entered in the z2m configuration if z2m runs outside of HA?
Thank you in advance!
Best regards
Gerd
gerd1
(Gerd Rütten)
January 22, 2024, 6:19am
3
Hello @francisp ,
thanks for your support.
So, I tested it with the entry, but z2m doesn’t start.
Imho that can’t work either, because in the “external” container in which z2m runs, “core-silabs-multiprotocol” is not defined at all… or where is my mistake?
Best regards
Gerd
francisp
(Francis)
January 22, 2024, 6:22am
4
Indeed, if they are not on the same docker network, you need
port: tcp://www.xx.yy.zz:9999
where www.xxx.yyy.zzz is the IP of the HA instance.
gerd1
(Gerd Rütten)
January 22, 2024, 12:55pm
5
i test it with the IP-Address from my HA, but z2m doesn’t start … I’m at a loss
