After adding a sonospollytts node it works fine. But when restarting node-red (e.g. because of an Hassio update) the node-red add-on fails to start. This behavior is independent of which port is set in the Sonospollytts node. After deletion of the node red flow using sonospollytts node in /config/node-red/flows.json the node-red add-on can be started without problems again. Seems like the Webserver started by sonospollytts is somehow conflicting with node-red’s Webserver?
Any help appreciated.
BR
Marc
